Question about HP LaserJet 4250dtn Printer
Tel me the processedure of duplex printing - HP LaserJet 4250dtn Printer
    Brigadier General:
  • 4,090 Answers
Dupoles printing can mean different options in different hardware and software. It can refer to two pges condensed to one A4 in landscape or it can mean odd and even pages on two sides.
Most office suite packags give you the option of duplex in the same way leaving the hardware unchanged which is the best option oveall.
You can printy all ODD pages then reinsert and have it print even pages on the other side and then all you do is colklate them. OR you can print side by side fromn 1- whatever.
By using software option it leaves the printer in its native mode without having to reset ity for the next job
Please rate my help++++Thanks for using FIXYA
Posted on May 29, 2010
I have a pc and a macbook pro. I can duplex print on the pc but cannot seem to duplex print on the mac using word 2011. How do you duplex print using a mac and printing with a Samsung CLP 510 EMAIL
To print duplex on a Mac:
1. After finishing your document, go to File >> Print. You will see something like the following:tcdb28.png
2. Make sure that Layout is selected: tcdb28_0.png 3. Under two-sided, make sure than Long-edged binding (or something similar) is turned on. tcdb28_1.png
This will allow you to print duplex (two sided) on the Mac.
Feb 09, 2011 | Samsung CLP-510 Laser Printer
What is it wanting me to do when it says "install duplex unit"?
A duplex unit allows you to automatically print double sided jobs. It sounds like a duplex unit is an option on your printer. If it is asking you to install a duplex unit, it is either configured for duplex printing i.e in your printer setup, duplex printing is enabled or, your driver has two sided printing enabled as its default.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
Duplex printing not happening
In your printer model duplex printing is not supported. But it can be achieved using the manual duplex printing option. In the printer properties select the type of duplex printing you want to take and click on print. Once the printing got over on one side of the papers, then you will be prompted to turn the whole printed paper bundle and keep in the tray again and continue the printing. Now by this way duplex printing is done in your printer model.
I hope this is useful to you.
Please rate the solution provided.
Thanks
Mar 31, 2010 | HP J4680 Office Jet All-In-One Printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
LaserJet 5MPHP
Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
Jan 05, 2010 | Office Equipment & Supplies
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
Jun 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
HP LaserJet 4250dtn Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
