Question about Dell (04U621) for Latitude D600, Inspiron 600M Motherboard
Will Not charge with brand new a/ power cord it will at times power on if moved the right way but quickly powers off if moved the port inside looks to be fine But I hear there is a pin type thing inside that wears out and needs replaced ?
    Scholar:
  • 52 Answers
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
Posted on May 29, 2010
I have a Vector LITE 117. It appears to not charge. I have replaced the battery with no luck. Is there something else that I should look at? I 've had it for sometime but it has had minimal use.
If the bulb is good, the charging port may be causing a bad connection. The charging port has terminals inside that prevents the light from being used while charging.
Sometimes, by quickly inserting and removing the power tip into the charging port several times can temporarily solve the problem.
Nov 14, 2017 | Vector Camping, Backpacking & Hiking
My iphone 4s will not charge
have a look at the port on your phone were u put the charging cord and see if the we part inside is broken or cracked and do the same on your power cord if u cant see anything wrong and u cheep u can always buy parts for them and take apart your iphone and replace the power socket
Aug 03, 2012 | Apple iPhone Smartphone
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
My dell inspiron 1420 wont charge without a lot of jiggling and moving the power cord around. i think it is the actual power whole inside the laptop. how do i fix this?
you are right, there is a partial contact inside the motherboard power pack. you will need an expert to do it for you, but if you are sure you can do it, just try opening the computer system and go straight to the port where the power cord is been plugged you will need a soldering iron and a lead to work on the board, around the port connector, you will see some broken soldering, all you need to do is to resolder the broken lead connection.
Oct 07, 2010 | Computers & Internet
How do I acquire a charge cord for an electric razor..."Zx4" 7797SCL ?
Many corded razors have a 110 cord that will fit. The Zx4 has a keyed receptacle. Depending on the cord you find (I used a Remington), you may have to whittle off the tang on the inside of the Zx4 power port. My Zx4 seems to be sensitive to polarity, it will not charge if the cord is plugged in backward. So when you get it to charge, mark the Zx4 case & new cord so you know which way to plug it in every time.
Sep 11, 2010 | Health & Beauty
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
My powerbok g4 got the metal tip of the AC power cord jack broken inside of the DC port of the laptop. This caused some sparks to come out of the port when the cord was plugged in again, so had to charge...
You need this part replaced bud:
http://cgi.ebay.com/PowerBook-15-A1046-DC-Power-IN-Audio-USB-Port-Board_W0QQitemZ130356686920QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e59dd3048
But you can't just buy this one. You have to buy the one that fits your model and processor speed.
Jan 09, 2010 | Apple PowerBook G4 Mac Notebook
This laptop no longer charges and does not turns
When you hit the power button, do any lights flash? Did it just happen overnight or did you have to move your power cord in just the right position for it to work and it got worse over time?
First of all, check the power adapter with a multimeter. See if it is outputting the correct voltage (19volts?). If the cord is okay, then you need to look more at the motherboard itself.
A common problem if for the power port (where you plug adapter into) on the computer to break the solder connection to the motherboard. This is caused from the power cord being jostled around from normal use.
If this is your problem, it is fixable.
You can send it in for warranty work.
You can replace the motherboard.
You can take it into an electronics repair shop and have them resolder/replace the port.
You can take it apart yourself if you are experienced with soldering circuit boards.
I would have to physically see your computer myself to be 100% sure of your problem, I am just going by your description. So this leaves the possibility that there is a different problem that is causing all of this.
Hope this helps.
Sep 18, 2009 | Gateway Computers & Internet
Won't stay on when plugged in. Battery? Power cord is new, could it be the power port on the computer?
Hi !
It might be your power adaptor !
I am not sure, but usually it should have a red/yallow led while charging and green when charged !
Read your manual.
Also, check power settings in control pannel.
There, you can find power schemes that turn off your laptop automatically when some time pass.
Set NEVER when plugged on power!
Check screen saver settings (and turn it off - NONE)
Also it should not turn off if there is any user activity!
At the end, if you are sure that there is no problem with your power unit, than checking and setting power OPTIONS in control pannel, should solve your proplem.
Regards.
Apr 21, 2009 | Sony VAIO Notebook
Computers & Internet Logo
112 people viewed this question
Alun Cox
