How to install windows XP Pro without using cd drives
  • Arish Shareef
    Arish Shareef May 29, 2010
    do you have any Operating system already installed?
    Brigadier General:
  • 10,406 Answers
Find a computer with a CD-ROM drive.
Find a USB memory-stick that can hold 1 gigabyte.
Copy all the files from the CD-ROM onto the memory-stick.
Carry the memory-stick to the CD-lacking computer, and plug it in to a USB port, and install from there.
Posted on May 29, 2010
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
I'm having difficulty installing itunes over xp media center. it seems that both xp and itunes want to grap the cd drive. Any way out of this? Also I heard that xp media centre is cp pro with some add...
I am not quite sure what you mean by saying that the programs want to grab the cd drive. Neither program should be using the cd/dvd drive unless you are using it, neither program has sole use of it. Could you clarify if you are getting an error during the installation?
No you can't install XP Pro and use the same product key that you have with Media Center. You need to purchase XP Pro if you want to install it and use the product key that comes in the packaging.
Sep 24, 2009 | Microsoft Windows XP Media Center Edition...
Format pc without cd
You could use a copy of bartpe on a usb stick. same with windows if you know how to copy your original cd properly. Its actually pretty easy I have both bartpe and xp pro on a single stick and used it to install to an older compaq that had no cd drive. setting up the stick for bart pe can be a little bit of a challenge but there is plenty of help on the web for it.
Same with how to copy your original xp cd.
Aug 11, 2009 | Intel Computers & Internet
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Computers & Internet Logo
David Payne
David Payne
