Question about Craftsman Garden
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Ihave a craftsman 5hp(briggs&stratton) rear tine tiller. It will start up run 45 seconds to minute and stat to die. If I adjust the choke slightly it will take off running and do the same again. I have changed the spark plug,(drained gas tank, cleaned and refuled),clean carburator and air filter, adjusted idle adjustment. Any ideas or help would be greatly appreciated.
  • john grant May 30, 2010
    Sunneyskies I want to thank you for your input. My carberator is mounted on the gas tank. i pulled it off and cleaned the detachable pickup filter. i pulled out the needle and seat it was clean and free. the hotter the engine gets it seems the quicker it dies. If you have any other thoughts i would appreciate them. Again thanks so much for your help.
    (5 hp briggs and stratton/craftsman tiller problems)
  • 61 Answers
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
Posted on May 29, 2010
Hi I have Crafstman Tiler front line 24", it start but can't get the fast idle, Thanks
Posted on Jun 05, 2011
I have a PowerPro 5 hp rear tine tiller with a 5hp B&S engine mdl 352-02. Where can I get some schematics of the engine?
First you need the model and type from Briggs then you can look at several online source for engine's ipl,
Here is some guides on finding your engine's numbers.
Briggs Stratton Model Number Locator
hey also have the ipl and parts for you to order from or you can support your local dealer.
May 10, 2015 | Garden
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 | Garden
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Garden Logo
679 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
