Question about NexxTech NPCINIC Network Adapter
Card installation I cannot install on my computer. When I follow the new hardware wizard, the drivers are not found even though I have the CD-ROM that came with the card in the drive. In addition, I downloaded the driver and it still won't recognize the driver from the wizard. Can you help me out?
  • Anonymous Apr 12, 2008
    I HAVE NO ITs software.
  • 105 Answers
Check for proper fitment and may non plug and play device hence you need to manually add it from control panel using "ADD NEW HARDWARE" by answering questing coolly. If Win Vista it is not supporting 10 mpbs of any model.
Posted on Apr 17, 2008
SOURCE:
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cd rom not working
Have you tried unplug cd rom drive then reboot and plug it back in should initiate the found new hardware wizard if it does not initiate the wizard try control panel add new hardware wizard and follow the prompts you will get to the screen asking you if you have already connected the hardware click next will open a screen with all your connected devices hopefully your cd rom drive will be listed if not it could be a power\lead problem or a driver problem
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 03, 2010 | Dell Computers & Internet
Show to install sound device driver in windows xp ?
  • 1 Insert your driver disk into the CD/DVD ROM drive. The disk should automatically boot. Then follow the on-screen instructions. This usually entails clicking on "Install" or "Install Sound Driver."
  • 2 Download the sound driver specific to your card and Windows XP. Driver websites include Drivers Kit, XP-Drivers and Driver XP. Locate the make and model of your card. Click on the manufacturer and then select the "Download" link.
  • 3 Double-click on the sound driver. The application will go through a setup process. Follow the on-screen instructions.
  • Manual Installation
  • 1 Click on the "Start" menu. Select "Control Panel," then scroll to "Add Hardware" and click to open. Sometimes, the automatic installation does not work properly. You will then need to install the sound drivers manually.
  • 2 Read and use the "Add Hardware Wizard." Click the "Next" tab. Windows XP will scan your computer for components.
  • 3 Scroll down the list to "Audio Drivers" or "Sound Drivers." Then click "Next." Select the "Finish" tab. Another window will appear.
  • 4 Select the "No, Not This Time" option on the "Hardware Update Wizard." Click "Next." Choose the "Install from a List or Specific Location" button. Then click the "Next" tab again.
  • 5 Place the sound driver disk in the CD/DVD ROM. Point the "Search Option" to your CD/DVD ROM or download folder. Click the "Include This Location to Search" box. Type in the path to your download folder or select the "Browse" option. Search through the computer to choose your download application. Click "Next."
  • 6 Wait until the file installs. This takes approximately two to three minutes. Turn up your speakers and reboot your computer
  • please rate my service with 4 thumbs up
    Nov 23, 2010 | Computers & Internet
    No sound on my pc!
    step 1: check with the speakers on another computer to ensure the speakers are working fine.
    1. Insert the CD-ROM titled 'Fujitsu Technology Solutions Drivers & Utilities CD' that came with the computer into the DVD tray and close it.
    2. The Drivers & Utilities CD will start automatically.
    3. Click on 'Driver Installation' option.
    4. Click on INSTALL.
    5. After the installation process the computer will automatically re-start. If not, for safety reasons (to not misinform/corrupt the information on the registry) restart the machine manually (Start Menu - Shut Down).
    If you receive a message saying 'Found New Hardware Wizard' during the Drivers installation (Automatic recommended), ignore it and leave the Drivers & Utility CD to finish the installation. The D+U Setup is will detect the computer's hardware (it will not detect the drivers of any external devices you may have) and install the drivers needed. After you re-boot the machine you may get the Found New Hardware Wizard again, this will be your Monitor being detected, follow the on-screen instructions to install it properly (if you have a driver's disk, provided with your monitor or any other external device that you have connected, use this when prompted)
    Jul 01, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
    Pleease reinstall printer driver after installin AIO 966 driver
    There must be some misunderstanding. Let me give some hints, First, remove the cartridges, unplug the power cable and the usb cable. Now power on your printer and leave it for few minutes. Again, plug/reinsert them and power on (make sure you connect the usb to the printer as well as on the computer usb port). If you get a small window "Found New Hardware Wizard" then insert you cd into the cd/dvd rom. Select "No Not this Time only" from the "Found New Hardware" wizard and click "next" then select "Install from a list or specific location" click "Next", check the "include this location in the search" click "browse" and manually search the driver to you Cd rom directory. After you locate the driver, click "Ok" then "next", the wizard will search and install the driver and click "finish" when it's done. Do let me know if this helps or not.
    Jun 01, 2010 | Dell 966 All-In-One InkJet Printer
    Setup
    a driver must come along with your sound card..shutdown PC..open casing and insert sound card in appropriate slot..turn PC on...right click My Computer..properties...hardware then device manager..on device manager click action then scan for hardware changes..the new found hardware wizard should pop up upon detecting the newly installed sound card..insert installer CD and follow instructions on the wizard... when finished restart and enjoy..
    Jun 19, 2009 | Intel RME968PAD Sound Card
    Driver is not installing
    Check that the driver is compatible with your operating system
    Vista or XP.
    My card has 2 type of drivers
    1 for XP and the other for Vista
    You may be trying to install the wrong one
    Dec 11, 2008 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
    Installing in progress, cannot install anything while programs are being installed
    unplug printer from your pc then restart the pc. then connect the cable to pc then if your printer found u get new hardware found wizard then insert your cd into rom then clik on "yes this time only"in new hardware found wizard.then it automatic get driver from cd.also u can manually install driver with browse the folder.
    Sep 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
    Computer doesn't recognize camera
    Remove previous all installation/ file if any. Insert the Driver CD in the CD ROM again a wizard interface would be active, from that wizard complete the installation by clicking Next - Next. Do not plug the camera before fresh installation complete. If wizard ask to plug your camera, then plug it.
    Jan 21, 2008 | Canon PowerShot SD850 IS Digital Camera
    Open Questions:
    \Q;- KODAK PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KODAK PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KODAK PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the KODAK PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, KODAK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK PRINTER USA Calling KODAK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK PRINTER USA's phone numbers against each other. Contacting KODAK PRINTER USA in General While [+I8OO-8O3-1O69] is KODAK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK PRINTER USA.
    Oct 18, 2019 | Kodak Computers & Internet
    \Q;- TOSHIBA PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This TOSHIBA PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 TOSHIBA PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the TOSHIBA PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, TOSHIBA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA PRINTER USA Calling TOSHIBA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA PRINTER USA's phone numbers against each other. Contacting TOSHIBA PRINTER USA in General While [+I8OO-8O3-1O69] is TOSHIBA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA PRINTER USA.
    Oct 18, 2019 | Toshiba Computers & Internet
    See all NexxTech NPCINIC Network Adapter Questions
    NexxTech NPCINIC Network Adapter Logo
    Top NexxTech Computers & Internet Experts
    Steven Wander
    Steven Wander
    Alun Cox
    Joe Goldman
    Joe Goldman
    Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
