Question about Dryers
How do i refit the drom belt onto my simpson sirocco 455 and refit the metal frame with the plastic pully wheel on it if i can get the diagram to do this please and how the belt configuration for the drum belt to go back on
  • 10,319 Answers
I looked all night for an illustration although none were found
The belt loops through the pulley first before attaching it to the drum
Feed the belt between the pulley and the bracket area that has the tension springing back and forth
Then attach the belt to the drum
Posted on May 29, 2010
  • eddie943 May 29, 2010
    where does the tension spring hook on to the outside cabinet to the dryer
  • frank thomas wilson
    frank thomas wilson May 30, 2010
    The bottom of the tensioner bracket simply attaches to the bottom of the dryer by slipping it into the straight slot adjacent to the revolving drum
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Clothes dryer stopped working while it was working Simpson Sirocco 455, what could be wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 26, 2011 | Dryers
Like many others I have having problems in fitting a new belt to a Simpson Sirocco 350. Who ever designed this machine did not want it repaired. I fix a lot of appliances over the years but this one has me...
Thanks Harry. This problem was driving me to a state of profane fury! Without your advice, my driver would have been added to landfill. Cheers. Alan
Aug 23, 2010 | Dryers
I need to replace a simpson sirocco lint cover spindle Do you no where i could purchase one. the plastic casing on the spindle has broken and the lint cover will not stay on.
I'm not sure where you can get one as i am in australia but an appliance spare parts outlet should have one or order it in for you,alternatively try simpson or electrolux.
Jun 01, 2010 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
I'm having a problem re-fitting the drive belt to my Simpson Sirocco 455 tumble dryer. After installing the belt around the drum, drive pulley and tension wheel, I align the front end of the drum with the...
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Cheers,
Andy B.
May 02, 2009 | Dryers
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
Dryers Logo
312 people viewed this question
Top Dryers Experts
