Question about Kenmore 67632 Electric Dryer
My Kenmore series 70 electric dryer isn't heating. Replace element, thermostats, ?
  • 166 Answers
A heating element would be a likely cause however before you replace the element you should check to make sure that it is bad by using an ohm meter to check the element for continuity. if you take the element out of the machine you can usually visualy inspect it and see the broken wire.
Posted on May 29, 2010
dragonsthatk
  • 547 Answers
SOURCE: new thermostat, still won't heat
heating coil broken
Posted on Feb 11, 2009
  • 1122 Answers
SOURCE: kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
Posted on May 11, 2009
MNfisherman
  • 11896 Answers
SOURCE: kenmore series 70 dryer will
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Posted on Oct 10, 2009
vostendorp
  • 347 Answers
SOURCE: My Kenmore 70 series electric
Their are only a few things left. assuming you have 240 volts,120 on each leg going into unit, the operating thermostat could be the issue. another possibility but not as likely is the centrifugal switch on the motor. You may have to measure the voltage at the heating element on each wire going to the element to find out which lead has the incorrect voltage
Posted on Sep 21, 2010
  • 2330 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kenmore 70 Dryer won't heat
Hi Jason
There is no fuse to replace only thermostats/thermistors...and heating element.
Here is some things to check:
Apr 25, 2013 | Dryers
Kenmore dryer 70 series 66722690-everything works except does not heat
It is probably either the thermostat (sensing too hot a temp) or the heating element. Either is not that difficult to change.
A word to the wise: When I replace one I like to replace both. One of the first times I replaced an element, within a month I had to open it back up and replace the thermostat. And it has happened more than once, so now I replace both.
May 15, 2012 | Kenmore Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
heating element
thermal fuse
thermostat
timer
Oct 10, 2009 | Kenmore Dryers
Have a Kenmore 70 series electric dryer, runs great but is not getting heat? What should I do to fix this?
#1 make sure you have 240VAC at the dryer
#2 check the heating element and/or the thermostats
Jun 08, 2009 | Kenmore 62882 Electric Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 67632 Electric Dryer Logo
288 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
