Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Heater is shaking and making a loud noise when
Hi Guys, rapak heater is shaking and making a loud noise when turned on and temp showing on the heater for spa rises rapidly. The spa is currently set to circulate seperately to the pool. Of course it is Saturday so pool company closed and we have a party tomorrow! Hope someone can help. Cheers Sarah
    Top Expert:
  • Raypak Master
  • 8,694 Answers
Not enough water flow if filters and pump ok check manual bypass for bad spring if ok see if plumbing bypass it should only be half way open
Posted on May 25, 2016
  • 61 Answers
SOURCE: I have a raypak p-r405a pool heater. When i hit
Some raypaks have a remote setting. I cannot remember the exact keys to hold to change it but i think that you hold both the up and down arrows for like 10 seconds. The instructions on the particular heater that i was working with were right on the display panel, but if its not there it will be in your owners manual.
Posted on Apr 06, 2009
  • 139 Answers
SOURCE: spa draining into pool
check should be on spa return line from filter or heater. its 1 1/2 or 2 inch pvc
Posted on Aug 11, 2009
  • 246 Answers
SOURCE: Pool heater shuts off itself before the set temp is reached
need new board control kit
Posted on Aug 25, 2009
  • 40 Answers
SOURCE: Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Posted on Sep 05, 2009
  • 279 Answers
SOURCE: pool heater will not turn on, elec. power good,
Check the limit switch. It may be stuck open and if it is it stops the unit from running. Also check thermostat setting and make sure it is working. Make sure the flame sensor is working. The system will start sometimes but if the flame sensor doesn't see a flame it shuts down. Good luck...Lee
Posted on Nov 06, 2009
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Noise
is this heater is been install for above the ground pool it will be better either way to use a hard schedulle 40 pvc to prevent any checking in the hoses for future leak ,is the heater connections are correct in and out , mean from the return the filter go to inlet side the heater them the outlet side of the heter (HOT WATER) GO TO RETURNS of the pool ? also check if the pump got full prime not air,is the filter is clean? also check for any brocken parts inside the flowvalve control, after years low PH AND TA will destroy internal parts in heater include leaking heater exchangers.
Jun 09, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a H100ID1 natural gas heater. For the past 2 weeks it has been heating the water but making a loud banging noise and shaking the whole heater. It stopped making the noise and won't heat the water....
Is it leaking? Has anything shaken loose inside? If you can get it to light the cause and fix for the banging and shaking is here: https://sites.google.com/site/haywardpoolheater/
Takes about 30 minute and you are done, but you have to figure out what else has gone wrong to stop it lighting
Jul 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Nov 05, 2009 | Heating & Cooling
Loud noises, shaking, visible white powder in chlorinator
Stop using the heater immediately. You are boiling the water inside and this can lead to a dangerous situation if a limit switch fails to act in time.
You will likely find the diverter in the inlet side of the heater is broken. You are looking for a stainless steel plate in the water path. If you can move it by hand, it is broke. It is not replaceable and requires a new heat exchanger assembly to repair it.
Your part number is IDXHXA1101. We sell it as will most pool dealers. If you would like a quote, contact us at www.arrowmotor.net
Jun 16, 2009 | Hayward H Series Induced Draft Abg 100,000...
Air conditioner and heater makes loud noise when turned on.
This might be the noise problem in your blower.The blower is out of balance with this added weight.5610f51.jpg
Apr 27, 2009 | Chevrolet Lumina Cars & Trucks
99 Grand Prix Heater only works on 5 makes a Loud noise
hi there
it sounds to me that you have two problems the
loud noise is the heater motor bushings is worn out causing the loud noise and vibration
also you will have to replace the resistor
once the motor is replace and the resistor replace all should be ok
don
Mar 09, 2009 | 2000 Pontiac Grand Prix
Heater making angry noise!
Your heater fan bearing is shot,,time to replace Fan now before you really need it.
Jan 19, 2009 | 2004 Mazda 3
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
468 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
