Question about Sony BRAVIA KDL-46W3000 Television
I moved from Japan to Texas and my Sony 46w3000 didn't have any problems until about 3 months afterward. Suddenly, one horizontal band, about an 1/8 in width began to form at the bottom. This went away after about 15 min of the tv being on. Now, it has been six months and the bands have quadrupled and they come an go. The bands progress from bottom to top and do go away for a moment if you lightly shake the tv (very lightly). I have attempted the reset and do not think this is the problem because it does not help. I do think it is a mechanical issue (maybe a connection knocked loose slightly but enough to transmit image). The progression tells me, like a disease, the connection is slowly getting worse. Please help me with a solution to this problem. I have downloaded a service manual and do not mind getting into the back of the television and fixing it.
  • williamrunkl Jun 21, 2010
    I called a repairman and he said that I have to replace the D-module. He also said that the D-module is the corridor for all of the transmission. So basically he inferred that I was scr-wed because the module itself costs around $750, which is roughly 2/3 the cost of my television. So, with that said...do you think he is right or do you disagree and think I should still take the television to a repair place? Oh, by the way...now there is a black ghost floating on the left side of the screen.
  • williamrunkl Jun 24, 2010
    Uh, you need to look at the previous repair suggestion. The gentleman that gave me this advice said itwould cost thismuch
  • Sony Master
  • 3,866 Answers
This is called a bad solder lead or cold solder joint when they started to use lead free solder in factories these issues started to bloom not just in your TV but others too. You might want to consider taking it to a shop locally to have the situation repaired I amsure if it is something that needs t rework it will not cost much say about $50 at the most.
Thanks and please do leave postive feedback and ratings.
Posted on May 29, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Jun 25, 2010
    Lead free solder cracks, case in point, other's would argue. $750 for the board or the job?
    I feel you need to out wiegh the first comment with your first comment not with the secound comment. So if you where told $750 by this one Welcomejee guy, you might want to reconsider your options here. If its a loose connection and a rework need to be done $50 in materials is what it would cost not the actual labor my goof sorry
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Horizontal shadow line
It sounds to be a back-light fault. Check the backlight inverter board, and back light. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 30, 2013 | Sony BRAVIA KDL-46W3000 Television
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Reader suddenly went beserk, lots of activity as though I were pushing buttons to change pages, etc. and then it stopped working properly; some part of the screen shows correctly while most of screen is...
separtdifge3,
Probably a charge issue, try this:
1. Connect the reader to the computer for 15 minutes (make sure there is a red steady light)
2. Disconnect the reader and press the reset at the bottom
3. slide the power switch to turn it on
4. If the problem persist you will need to do a hard reset
5. If after a hard reset the issue is not resolve problably you will need to contact sony to get it repaires =(
eBookBoy
http://digialreader.freeforums.org
Jul 01, 2011 | Sony Reader Touch PRS-600
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
Sony kdl-46xbr4 Black Horizontal Bands When I First Turn on TV
I had the exact same problem with the Sony KDL46XBR4. The problem started 11 months after I purchased the TV (Dec 2007). Luckily I placed the call to Sony just before the 1 year warranty expired and they replaced the entire front panel which is basically the whole TV except for the stand and the plastic frame. Last month the same issue started happening again (5 months since the repair). I called Sony and they say they have a 90 day warranty on the replacement part so I would need to pay out of my own pocket to first have the problem diagnosed (it's the EXACT same problem!) and then pay to have the repair done since the warranty has expired. I asked how much the front panel costs and it's $1,400! I paid $2,100 for the TV when I purchased it. Interestingly, at the time that part was back-ordered.....hmmmm, I wonder why??? Perhaps a recall is warranted here (no pun intended). Needless to say, I have sworn off Sony products due to their lack of support for this issue.
Jun 01, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Banding on pictures
Hello, the new memory stick will not solve the problem. If you need more info please advice.
Apr 18, 2007 | Sony Cyber-shot DSC-T9 Digital Camera
Sony BRAVIA KDL-46W3000 Television Logo
157 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
