Question about Rinnai EnergySaver 556 Air Conditioner
Error code 11 on a Rinnai energysaver 556FTR
Has not been used for a while. We have just moved to property with this heater and have no manual
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Rachel,
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
Tom
Posted on Jun 02, 2010
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai Energysaver 1001 without a manual, we have just moved into our new house and manual not left. Where can I get manual from? TA
all energysavers have the same controls so any manual will do. www.rinnai.co.nz navigate to Tradesmart, space heating, energysavers.
Jun 13, 2009 | Heating & Cooling
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Our heater 556ftr is got a code error flashing, 14
I found the manual on the net and it said error code 14 is overheating, it suggests to clean the filter, but my filter was clean, so I'm wondering if my flue has been installed incorrectly. On mine the error code is staying on after switching the power off and on, so this means my thermal fuse has blown.
Aug 08, 2008 | Rinnai Heating & Cooling
Rinnai EnergySaver 556 Air Conditioner Logo
669 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
