Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Eam3500 delonghi coffe machine
Unit show General alarm fault after warm up.
Any possible causes?
  • 25 Answers
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
Posted on Jun 29, 2010
    Problem Solver:
Dan, good morning, I tried what manual recommends, took machine to appliance serves and was told that control board needs to be changed. What is your experience on that. Also this machine has to have it's own surge protector in case of power default. That's what happened to mine when we have power surge going back and fourth few times- at that time I did not placed power surge protector. It turned out to bea pricy mistake.
Posted on Oct 19, 2011
Delonghi EAM3500 problem in power board (part no 5232109900)
There are lots of Delonghi spare parts on the website komtra
Unfortunately the page is in German.
A new Power board is available for 72 euro
Dec 03, 2013 | Coffee Makers & Espresso Machines
My DeLonghi EAM3500 display "general alarm" and
It is best that you contact the customer care of DeLonghi and post your request. you can also register your product for support.
The power supply can be sourced after the price is confirmed as these are available only with their spares department.
click on;
http://delonghiusa.com/support/
Oct 18, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Aug 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Milk steamer not frofing properly
As others have pointed out the rubber 'O' ring seals may be missing or damaged preventing a good seal.
But another problem can be the water heater (horse-shoe shaped) not getting up to a high enough temperature. This can be caused by the thermal sensor going open circuit so indicating a high temperature to the electronic control system. When the unit is cold (at room temperature) the sensors should measure about 120K ohms resistance.
When this fault occurs your cappuccinos will be luke warm and the milk will splutter out of the spout.
Aso ensure you de-scale the unit as this will restrict the water flow and act as an insulator, reducing the effectiveness of the heaters.
Mar 30, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Coffee from my DeLonghi Magnifica does not seem to be hot enough.
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
Jan 24, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
General Alarm
I have the same problem how did you fix this ?
Jun 26, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Delinghi eam3500 has come up with general alarm, I have cleaned the unit like it says but it is still not working, when it turns on it says warming up, but it tries to warm up for ages but nothing...
The general alarm message after the machine taking too long to heat up -in deed shows a problem to reach the correct temperature.
So there are a number of possible causes:
the 2 heaters (water/steam) the NTCs(temperature control sensors)
the tempearature overheat-fuses. In my case it was the (water-)heater itself. Be sure to unplug the machine from power supply befor opening!!!
First test then-do the heaters warm up??.....carefull if they do-they are hot!!! If one of them doesn´t warm up- Unplug again!...and then measure the resistance of this heater-If the heater is ok,it should show around 50-58 ohms. If it shows indefinite resistance the heater is broken and you have to exchange it.
In case of both the heaters showing the~50ohms you will have to check the thermal resistors/fuse/NTC.
For me the two forums below wer of great help for me...of course they are in german...but didn´t you wish to learn a foreuage anyway???
Good luck and best regards
Wolfgang
Ref,:http://www.kaffeevollautomaten.org/forums
http://www.kaffee-welt.net
Dec 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
2,708 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
