Question about Minolta X-700 35mm SLR Camera
I took the lens off my Minolta x-700 camera, and a rectangular piece of plastic came out. Is there a way that I would be able to fix this, or would I have to bring the camera to a repair shop?
  • Obertelli
    Obertelli May 29, 2010
    Sorry, but unless you can include a link to a diagram or clear photographs it's impossible to give you a definite answer.
  • dpriff3 May 29, 2010
    Sorry about that--I believe the piece of plastic is the shutter. It's now completely out of the camera, and I was wondering if I would be able to fix it, or would I have to take it to a repair shop. Also, would the repair cost more than the camera is worth?
    Thank you.
    Brigadier General:
  • 3,006 Answers
If the piece is actually the shutter then the camera is now junk, sorry. Repairs are not economically viable and the parts are no longer available.
But I doubt it's the shutter as the shuuter curtains are either fabric or metal.
If you can't post a photo, then by all means take the camera to a repair shop and they'll tell you what the part is and where it goes.
Posted on May 29, 2010
I have been offered a SiGMA 400mm F/5.6 manual lens for a minolta mount. Will it fit my camera? Cheers Pete
Minolta had two lens mounts. One for manual focus SLR film cameras and one for Auto Focus SLR Maxxum film and digital SLR cameras. Sony uses Minolta Maxxum lens mount.
If the Sigma 400 f5.6 lens was made for Minolta X-700 series, XG, series, XD series, SRT series, then it will not fit on your camera.
Jun 17, 2010 | Sony Alpha DSLR-A200K Digital Camera
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
Feb 21, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My Olympus c-730 just fell on the floor while it was on and landed on the lens. The glass lens and 2 plastic pieces came out and the lens housing is now crooked. It won't retract in or out. I tried...
I'm sorry to tell you that this means your camera is now dead.
You've broken the lens assembly, and probably the lens zoom/retract motor and gear assembly. There is no way to accurately repair them without replacing as complete sub-units: even if you could get it back together, the lens elements would be out of alignment. Spare parts have long since been discontinued.
Your camera is now about eight years old, so it's done fantastically well; very few digital cameras last more than five years. Unfortunately the only fix is to replace the camera.
Feb 19, 2010 | Olympus Camedia C-700 Ultra Zoom Digital...
CANON A70 - 2 YEAR OLD Took apart the lens
This link has some examples of repair of the automatic lens cover. It may help you figure out how to reinstall the lens cover springs.
Feb 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Have multiple Minolta X-700 bodies, the 400mm Minolta MD lens, does lock onto one body but not some of the other camera bodies. Any idea why?
If your other lenses lock on to all of the bodies, then it is quite likely that the notch on the mount edge of the 400mm is worn. The notch is located about 90 degrees clockwise from the red marker dot on the lens barrel. I doubt if there are new replacement mounts for that lens. You may be able to square up the edges of the notch with a small file.
Jan 23, 2010 | Minolta X-700 35mm SLR Camera
I have a minolta 404si. it recently took a fall and i dont no whats rong. there is no light coming threw the eye piece. the light meater keeps activating the flash. if i take the lense off there is light...
I suspect your lens is forcing the mirror up when it's mounted on the camera. This would cause a dark viewfinder and as the metering system is also in there then no light means that the camera thinks that it's in total darkness and activates the flash.
Try another lens. If the problem continues then the camera body is broken, if not then it's the lens. Most likely to be the lens though.
Used Minolta lenses are readily available at reasonable cost (or free if you ask on FreeCycle) so unless your lens problem is obvious and easy to fix then just replace it as spares are mainly non-available and labour charges are high. If you want a new lens then Sony retained the same lens mount when they took over Konica Minolta.
Sep 14, 2009 | Minolta Dynax 404Si Film Camera
Viewfinder internal lens array found rattling inside the Camera
Please take it to the nearest authorized service center. Since it is out of warranty, you will have to pay for the service. And it is a precision job. So better not to attempt fixing it yourself.
Jan 24, 2009 | Sony Alpha DSLR-A100 Digital Camera
STUCK ON STANDBY
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Sep 04, 2008 | Fuji FinePix A345 Digital Camera
Stuck in video standby mode! help!
Lori, the switch above the display may be broken. does it still 'click' at each of the 3 settings? (play,video,camera)
Mar 18, 2008 | Fuji FinePix A345 Digital Camera
Camera switches on then off
Check the Kodak website Tech support, It does seem that there is a switch fault or internal short here.
May 13, 2007 | Kodak EasyShare Z740 Digital Camera
Minolta X-700 35mm SLR Camera Logo
93 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
