Question about T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone
My G1 showed a blue light and it was off went to turn it on and would not turn on, What does the light mean?
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Blue light on g1 phone
blue light problem
Aug 04, 2010 | HTC G1 Smartphone
My g1 wont turn on when i try to hit the power button the top light turns blue and when i do the reset it dose the same thing
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
May 04, 2010 | HTC G1
Phone doesnt come on completely
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
Apr 06, 2010 | HTC G1 Smartphone
Phone will only show a blue light when trying to turn on
This means that the firmware is corrupt. Please get it reinstalled. Your data will be lost in the process. But there is no choice. And after the re-installation, get an anti virus installed too.
Mar 31, 2010 | HTC G1
Non-responding screen, blue indicator light?
I also got this blue screen,
I fixed it wiit a registry tool, it is powerful suggest you have a try!
Fix blue screen now.
Download blue screen fix tool.
Feb 28, 2010 | HTC G1 Smartphone
Blue light on top of g1
I solved this problem by booting into SAFE MODE on the G1:
Press Menu Button and Switch on the G1 Phone using Power button. (Do not release menu Key).
That Got it to turn on. but upon power down it did the same thing with blue light. So I always start in SAFE MODE. I will start uninstalling programs until i find out which one is causing problem.
Sep 11, 2009 | HTC G1
My fones blutooth isnt workin
Sounds to me like your G1 isn't set to discoverable. Should be an option for it in the bluetooth section. Then go ahead and try to pair them, also make sure your bluetooth is in pairing mode, most bluetooth headsets get be set to this by holding down the on button for over 5 seconds and usually shows as a constant blue light.
Jul 18, 2009 | HTC G1 Smartphone
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Phone went off only blue light showing
well plug the charger into the phone with the battery still intact.....then remove the battery while the phone is still plugged in. then unplug the charger and plug it back in........place battery back into phone and then power it up. That worked for me.
Feb 01, 2009 | HTC G1
T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone Logo
195 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
