Question about LG LS-L1210CL Mini Split Air Conditioner
Water coming through indoor unit
Water is coming through indoor unit i had an lg air conditoner which i bought two months before but there is a problem
    Guru:
  • 1,524 Answers
Clean drain.
Posted on May 29, 2010
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Installed an artcool in my appartment and it constanly leaves a little puddle of water on the floor, irregardless of the temp setting or the fan speed. Drain hose is connected to the plumbing drain. Water...
first of all check the outdoor unit if it is in your reach  than simply touch both the valve & feel the temp if smaller valve is colder than the bigger one than surely the problem is with refrigerant quantity.
Jul 20, 2010 | LG Art Cool LA1000PR Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
ERROR CODE CH5 AIRCON SPLIT LG
This error is a communication error between your indoor and outdoor unit. You can try turning the breaker off for a few minutes and restart the unit. However if that does not work its best suggested to have an authorized HVAC technician service the unit.
Dec 24, 2009 | LG LS-L1210CL Mini Split Air Conditioner
The LG Window Air Conditoner was chose because it
try pressing around the unit with your hand while unit is running, the sheet metal may be loose or vibrating against something wedge it something and check for loose screws.
Jul 22, 2009 | Heating & Cooling
Noisy indoor air conditioning units
Ok. So first things first. LG have a reputation with all their products. THEY ARE ALL BAD! If you remember GoldStar, they are now LG. GoldStar had horrible products. Now this is what LG has. The fact that the filters are cleaned and the units are serviced is an abosulte plus and will provide the units with extra longevity. Now are these drains are they used for water drainage. If so the upstairs units shouldn't need them unless there is some sort of rise in the drain pipe.
Now to the noise. It seems like there is something which is causing the fan to make a noise. It could be loose bearing or a piece of the fan which has broken away causing it to hit the inside of the unit. Since it is on both units, it would be a generic problem with this series and unfortunately is what you are stuck with now.
To combat this problem, I would: ring LG and the company who installed them and demand that they be repaired and have a warranty on the repairs. Just a heads up, LG are really bad to contact should you have a complaint, so keep persisting that they be repaired free of charge since that they are still under warranty.
If you are not happy with LG or your installers response, I would remove the units and have another brand put in. I recommend Mitsubishi Heavy Industries and Panasonic. Both units are whisper quiet. In fact they are quieter that the LG.
Oh and that only reason why LG boast about their "whisper quiet-ness" is because that is probably the only good going for them - and thats' not even right!
I hope that I have helped you in some way. Good Luck!
Mat
Jul 14, 2009 | LG Heating & Cooling
Mr Slim split system with no display on remote control or unit display.
Mitsubishi Mr slim comes with no diplay on the indoor unit but there is small display on th eremote unit.for further help kindly send your air conditones complete model
Jul 09, 2009 | Heating & Cooling
My air conditioner
angela,
the slimy pink substance is the product of long usage and is a normal accumulation of dust and dirt.
have a regular cleaning of the unit to prevent another occurrence of the water not draining out. usually every three months depending on the location of the unit.
tnx 4 using fixya,
drcool
Sep 13, 2008 | LG Electronic Window Air Conditioner
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
284 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
