Question about GPX KCLD8886DT 8.1 in. Portable Television
Even if no one can help me fix this thing, can someone tell me how to open the CD/DVD drawer to remove the CD that's stuck inside? This is the GPX model KCLD8886DT. Thanks.
  • peinture279 Jun 02, 2010
    Thank you! The way this unit is made, I think I'm going to have to dismantle it. Oh, well, it doesn't work any more anyway.
  • 12,061 Answers
Hi, well if you look carefully you should see a small hole in the front of the tray, now using a straightened paperclip or similar, insert this into, this hole, and push in, keep pushing you will hear/feel a "Click" jeep pushing past this point, and your draw should "Pop Open". If you cannot do that, then the only alternative, is to open the case and get it out that way.
Posted on Jun 02, 2010
Cd drawers won't open, may have cd stuck in #1 slot
How to Fix a stuck CD Tray - YouTube
? 6:24
https://www.youtube.com/watch?v=gpvjqATX3Rs
Mar 24, 2010 - Uploaded by Guy Techie
Pin won't open my tray :( Help please?. Read more ... I was lucky to find a rubber band in my junk drawer and it ...
When a CD or DVD is stuck or the drive won't open ' PCWorld
Dec 09, 2015 | Audio Players & Recorders
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
CD Drawer will not open. Do you have any suggestions on how to fix
Does it look like it is trying to open but somehow it seem stucked? This would indicate a mechanical problem whic is most of the time due to loading mechanism has been misalligned.
Open the device so you can see the tray. The tray is removable. You to remove the tray manually and while it is removed plug the device in so it will go into it's default position. Then insert the tray back again.
Jun 01, 2011 | GPX KC218S CD Player / Recorder
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
My dvd player is plugged in, but it won't even turn on, The AV thing has part of a plug stuck in it that broke off and is stuck inside and won't come out- think this might have something to do with it,...
You should contact the company that made your dvd player and tell them your problem. they will probably send someone over. IF you have a receipt they may either fix your DVD player or give you another one.
Apr 11, 2010 | Insignia I-PD720 Portable DVD Player
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
Vcr/dvd combo, dvd drawer stuck open
they are either gear or "belt" (rubber band lol) driven trays the rubber band has slipped off or the gear is off track if your brave and skilled enough just open it up and reset it or fix it if not take it to someone who is
Aug 03, 2009 | Televison & Video
Fix
ok restart the cdmix1 it ll work..
Jun 23, 2008 | Nu Mark Numark (CD2CD) CD-RW Burner
GPX KCLD8886DT 8.1 in. Portable Television Logo
44 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
