Question about GPX KCLD8886DT 8.1 in. Portable Television
It worked fine. We went out of town and when we got home the clock/channel display is lit but blank. None of the buttons respond and there is a CD inside the drawer which won't open. Any suggestions would be appreciated. This is a GPX model KCLD8886DDT under counter/cabinet unit. Thanks!
  • peinture279 Jun 01, 2010
    There is no hole to use as a release for the CD/DVD drawer. I've tried the tapping suggestion but no results. The power button won't even turn on, although when it's plugged in, the display screen glows blue (with no display). Any other help to get the drawer open (outside of breaking it)?
    Thanks. It's what I suspected. I think I'll disassemble it and retrieve the CD. Beyond that...maybe a new product. Again, thanks.
  • 6,784 Answers
HI. This is a classic power surge issue. During your away time, there may have been some sort of power black out or surge that may have ruined the internal Micro Board. There are several logic chips mounted on this particular board. If the unit was left plugged in while you were away, This would expose the unit to this sort of damage. To confirm logic chip failure, simply unplug the unit for five minutes. Once the five minute reset has passed, re-introduce power to the unit and try to initiate a command. If you experience the same results as before(blank screen), this will confirm the failure to the internal micro board.
Internal PCB failure is very serious and will require you to have the affected board replaced, asap.
Posted on Jun 01, 2010
  • Michael Masters
    Michael Masters Jun 01, 2010
    Concerning the drawer:
    This is a mechanized gear driven drawer. Due to the fact that the main board has sustained over-current damage, this will render the actual drawer gear and motor assembly useless, therefore, causing the drawer to remain in the original position prior to the disruption. The only way to extract the CD will be to totally disassemble the casing. This will expose the internals and drawer mechanism. The gears will not move without proper motor function. The drawer will need to be forced, in return, possibly damaging the unit loader assembly(gears tracking rail etc..)
  • 712 Answers
Sometimes there may be a small hole beneath the drawer. Push a small pin through it and press the eject button. Then push the pin well into the hole. The drawer may come out. If the hole is absent, press the eject button and tap hardly above the drawer for a few times. The drawer will come out with the C.D. Sometimes you may have to tap quite for sometime. Give it a few tries and see if it works.
Posted on May 29, 2010
  • peinture279 May 29, 2010
    Thanks for your suggestion. So far, the tapping and pushing the button hasn't worked. I will try a few more times later on and see if I have any luck! There is no hole anywhere that I can push to release the drawer. And it's just a bit too small to insert something like a small screwdriver and pry it open. If you have any other thoughts I'd be happy to hear them and give them a try before asking for more help.
    If you google this item, you can see a picture of it which may give you some clue as to another way to approach it. It's mounted under my kitchen cabinets so I can't get at the top, but I don't recall any hole there. I will have to remove it soon at any rate, so I can check then and see if by any lucky chance there is a "release" hole that I can't see presently.
My new Kenmore Electric Range, model 790.9419, purchased July 18, 2014...The clock no longer works. I press "clock", the code CLO appears; I set correct time; press START and the display goes blank an
That's an enegy saving "feature" - the ability to turn off the clock. Usually (in most models), you can turn the clock display back on by pressing and holding the clock 10 to 15 seconds.
Sep 17, 2014 | Kitchen Ranges
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
The clock isn't lighting up/ the music isn't playing
the home was getting too hot i unpluged it for a while then i went back later and plugged it back it and it worked fine
May 29, 2009 | Apple iLive IHMD8816DTB iPod Home Docking...
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Dec 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
GPX KCLD8886DT 8.1 in. Portable Television Logo
71 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
