Question about Compaq Presario 700 470024-192 Notebook
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
  • 3 Answers
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
Posted on May 29, 2010
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
My macbook pro freezes and will not turn off or on
This sounds like a hardware failure.
Have you tried reseating the RAM?
Sep 01, 2012 | Apple Computers & Internet
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Multiple horizontal lines runnning across the
It sounds as though you have a poor signal issue. Firstly try rescanning all the channels. If no difference check the aerial/dish connections, then rescan. Lastly check the aerial/dish externally for misalignment and connectability.
Jan 03, 2018 | Samsung Televison & Video
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Compaq Presario 700 470024-192 Notebook Logo
225 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
