Question about Insignia IS-DVD1001 DVD Recorder/VCR
Dvd player stuck on progressive scan mode - Insignia IS-DVD1001 DVD Recorder/VCR
5 Suggested Answers
SOURCE: insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Posted on Jul 04, 2007
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Posted on Aug 10, 2008
SOURCE: stuck on progressive scan mode
try pressing menu
then down seven times
right once
up once
and enter
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: Insignia Home Entertainment System - DVD settings
You can try unplugging the unit for at least a minute. If that doesn't work, what a CSR told me to do to reset my unit was unplug it and while unplugged, push and hold the power button for at least 30 seconds. I hope this helps.
Posted on Mar 19, 2009
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
My xbv410 is stuck on progressive scan mode. I
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Mar 13, 2010 | Zenith XBV442 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Progressive Scan
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Jan 04, 2008 | Zenith XBV442 DVD Player/VCR
How to turn off progressive scan on Allegro Dvd Player
yeah.same here.=[
but it only says that for the dvd mode.
Oct 24, 2007 | Allegro DVD/VCR ABV511
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
284 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
