Question about Sun Java Desktop System
My Java stopped working when I took Norton's out and I can not get it working again. I have taken it out and put it back in several times and still it want work, it says it is working, but when I go to a web page that uses Java it does not work, can you help me?
  • 428 Answers
First please go here and check whether its functioning well. Sun Java Site If it doesn't work follow the steps.
Get latest updated one from here http://www.java.com/en/download/manual.jsp
This problem happens when Norton Internet Security or Norton Personal Firewall has been configured to block scripts, ActiveX controls, Java applets, referral information, or advertisements.
ActiveX controls and Java applets can be blocked by customizing your security settings from the main interface. To find out whether this is the problem, read the section "Customize security settings."
All of these security features (scripts, ActiveX controls, Java applets, referral information, and advertisements) can be blocked by specific Web rules. These rules are located in the Advanced Options of the program. For scripts, ActiveX controls, Java applets, and referral information, see the "Web rules" section of this document.
You have to configure the settings of your antivirus suite or/and firewall. Since I do not know which version of Norton you use (if you provided the version I could guide you further. Even if you have uninstalled the settings would be there. How to enable Java if disabled... http://www.java.com/en/download/help/enable_browser.xml
This answer is aimed at Java Runtime and Plugins in a Windows environment. Not aimed at any other operating system including Java Desk.
Posted on May 29, 2010
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Took off my Java, had 3 on
yer, handy for lots of things
goto
www.java.com click the free download
Nov 10, 2009 | Toshiba Satellite M35-S359 Notebook
1996 Jetta stops runing. I waite a while and it will restart until the next time. I replaced mas air flow sensor with new one. Now it will not start at all.
Just a thought, but I had a 1994 Jetta, and after having the timing belt and transmission replaced I had a similar issue. Whenever I would go anywhere and turn the car off it would not restart for a while. Turned out that the garage that did the work forgot to replace the heat shield somewhere around the transmission and the car kept thinking it was overheated. I took it back and had them put a new one in, since the misplaced the old one ( the reason they failed to put it back in in the first place).
If you have had anysort of engine work like that you may want to ask someone. I had taken it to several places asking about the problem, took a VW dealer to see the problem and they spotted it instantly.
Not sure if this will help, but thought I would throw it out there.
Aug 12, 2009 | 1996 Volkswagen Jetta
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Hello, Settings on my computer! I have been unsuccessful in downloading several programs. 1. Java 2. Norton I have downloaded AVG Security Free. But on #1&2.download does not start. Do I need...
First you need to tell us which web browser used. And then check whether if Java is already in the Add/Remove list.
Since you have AVG Internet Security 8.0 , there is no need to install Norton now.
Also check whether you have Flash plugin and active X installed on your PC.
Let me know if you need further assistance.
Oct 06, 2008 | HP Computers & Internet
Sun Java Desktop System Logo
256 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
