Question about Nokia Cell Phones
How to repair white screen lcd of 7360 - Nokia Cell Phones
  • Nokia Master
  • 624 Answers
Clean the connector first...
Posted on Jun 07, 2010
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
Screen white
Return it if the warranty is good. Otherwise find a repair shop that will look at it and tell you what is wrong, then find the part online and fix it yourself.
Mar 08, 2014 | RCA 26LA30RQD 26 LCD TVDVD Combo
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
I am trying to upload photos from my Nokia 7360 to my computer. I have the correct data cable and have downloaded Nokia PC suite but when 'get connected' tells me to connect the phone to the c
Try a different cable and/or different computer.
Sometimes, you will need to choose an option on the phone to allow data transfer.
I found this link: http://symptomdb.com/devices/nokia-7360-drivers/
Jun 05, 2017 | Nokia 7360 Cellular Phone
The screen on my hp mini 110 went white
A white LCD screen can be caused by (likeliness):
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard.
A local computer repair store should be able to fix this for you.
Jun 25, 2010 | HP Mini 110-1037NR Netbook
How can i repormat my nokia 7360 because i cant apply a themes
Try this. This works perfectly on nokia 6600 and i have formatting like this whenever im getting a virus attack.
Switch off and on . While the light on the screen appears hold these three keys, (Green call button+star Key*+number3. A vertical shade and the word " formatting "will appear on screen. Hold it till you finish the formatting. You will lose your phone memory. Im not sure whether this will work on 7360.
Oct 06, 2009 | Nokia 7360 Cellular Phone
Bluetooth and mp3
i want my 7360 to a bluetooth and mp3 activation,what should do?,and also my unit sometimes shutoff automaticaly and turn on after,and contact service appeared on screen. pls help me..?
Dec 11, 2007 | Nokia 7360 Cellular Phone
7360 SIGNAL
how do i unlock my nokia 7360, its locked to vodafone ireland
Nov 14, 2007 | Nokia 1100
Cell Phones Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
