Question about Dell XPS M1330 13.3" Tuxedo Black Laptop Computer. Sleek, Sophicated, and Truly Portable Laptop. Int... PC Notebook
Clock dont keep the right hour, date and sometimes year
The coin battery is ok the computer works perfect except for the clock when the year is not wright it goes to 1610
which motherboard is the one i need what number part?
    Sergeant:
  • 356 Answers
Hi. Try updating the BIOS first by downloading it from support.dell.com.
^_^
Posted on Jun 05, 2010
Re: hp compaq 6910p laptop start button stays lighted, as does volume indicator, and sometimes two colors on he ethernet plug-in. The start will not turn off. And it will not start computer. And...
Hi, please try first by unplug charger and then remove battery, after about 10 minutes, insert battery again and plug it charger, only the battery charging indicator should light on, if the status of other indicators keeps in the same way, maybe the motherboard is faulty and needs to be replaced, in such case, don't worry about your data, it can be recovered since hard disk can be taken apart from your computer to be connected to another one to access your data.
Nov 07, 2017 | HP Compaq 6910p Notebook PC PC Notebook
My laptop will not power up
Rule out: Water damage. Rule out, power supply, damage to cord, damage to plug end that fits into the computer power port. Check computers power port for bent female contacts. Battery can also be a problem. Some laptops will not function if the battery has lost charge or is dead. If none of the above, a CPU going bad or hard drive dying, will also cause the computer to fail when energizing.
Vest you have a computer technician look this over.
Feb 17, 2018 | HP EliteBook 6930p Notebook PC
Clock will not set for correct time. Manually change but this does not work.
Most likely the CMOS (Bios battery), which is a small silver coin shaped battery on the motherboard needs changing. This maintains the correct time when the laptop is switched off. They last for up to 3 years then need replacing. (example in picture)
http://cgi.ebay.co.uk/CMOS-RTC-Battery-Toshiba-Satellite-A105-Series-/270751984156?pt=US_Batteries&hash=item3f0a136a1c
Be careful in changing the battery, If you have not done this before, refer to a computer repair shop.
Jul 14, 2011 | Toshiba Satellite A105 Notebook
How to change battery on asrock k7s8x motherboard
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 03, 2011 | Asrock K7S8X-R3 Motherboard
Do I have to replace battery from motherboard, the clock doesn't work and it gone back to 2002 year, etc... Motherboard ASUS P4SP-MX
Turn the computer off.
Disconnect the AC power.
Remove the side-panel.
Look on the motherboard for a round, silver-coloured, circle,
about the size of a $0.25 coin.
Before you gently "lever" it out, look at the printing etched into the top of the battery -- you'll have to insert the replacement battery in the same orientation.
Take the battery to a computer-store, and get them to sell you a matching battery.
Press the battery into the socket in the motherboard.
Restart your computer.
Enter BIOS SETUP.
Use 'Load Default BIOS Settings'.
Save/Exit.
Jul 27, 2010 | ASUS P4SP-MX Motherboard
The motherboard 27HRF can work with my dell
You should replace this board it may an internal issue such as a shorted trace of surface mounted component. Not worth the effort to do board level troubleshooting and there are replacement board that will fit the Dell cabinet you have. Call Dell support to make sure that you can use a #rd party board substitution.
I hope this helps. Have a great holiday weekend.
May 29, 2010 | Dell (27HRF) Motherboard
I have windows 7. When I shut down and then restart later or the next day the clock shows the time of shut down and then run ok but I have to reset it or click on internet sync and that works. Then the...
If this is an older PC (3-5 years or more) then most likely the backup battery on the motherboard has become weak.
On many motherboards this is a coin cell, which can easily be replaced (on others it is soldered in, though), just have a look.
Mar 24, 2010 | Computers & Internet
Black screen please help
the beeps are called BIOS BEEP codes. and is telling you what is wrong.
does run with no battery removed
do the BIOS screens work they MUST at all time. power on ,hotkeyed.
is the fan running
its old right,
like an old car that will not start do you buy a new car?
or buy a new battery? hummmmmmmm
ever heard of a tech>/? those folks that diagnosis things?
tried taking battery out, but failed to say it would not run only on the power pack. take it out and leave it out for now... be wise.
so the HP logo works every-time you never said that yes./no.??
thAT hp LOGO IS A BIOS LOGO FROM HP.
if yes the BIOS is ok. see? means the brain works the Ram is not dead and if you had pressed the BIOS hot key F1,F1, Esc, F10
what ever it is , it tells you what at boot in text. if you look there.
if it stalls with good bios that means.
bad HDD or bad OS.
SOME NEWER PC HAVE f10 OR F11 RESTORE KEY
IF YOU Press that, at power on ,it goes to restore mode.
(means reload windows)
oops HP retired this PC
https://support.hp.com/us-en/retired-products
that means in English clear, its NOT SUPPORTED NOW.
no books no software no updates no NUTTN
No anything, !
now you know why mom dump it.?
LOL !!!!
its a dead fish.
or FORD, found on road dead. LT.
why not report the beep codes
clear and accurately,??????????????????????
run the LT with no battery and level it like that till cured.
then, replace the COIN cell, no laptop this old has good 3vdc coin cell, impossible I bet.
if the cell dies, as all do in 5 -10 years.
the PC beeps with CMOS clock, NVRAM errors.
the battery size of a coin, runs the Real time clock and the
CMOS memory bank for the BIOS settings.
if the coin goes dead BIOS GOES NUTS ANT TIME/DATE goes NUTS.
if the beep codes say the HDD dont boot that usually means HDD is dead.
the trouble with beep codes are that there are many BIOS used
and many codes used. some are impossible to find.
beeps are now gone we flash LED codes now.
this is DT coin, LT is warped in plastic and 2 wires. see the COIN?
http://www.pcdied.com/coin-dt.JPG
beep?
1 long , 1 short, ? is COIN dead.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
note the black hole OF BIOS code HELL here, its a bad place to be.
for sure.
one other test is go to BIOS page.
see that time/date, year, settings. if way off the COIN is dead.
learn to that a 1/2 dead coin can work now, then file and 1 hour later work, that is how batteries fail. they go MARGINAL sometimes.
Apr 03, 2017 | Compaq Presario 1800T Notebook
Monitor won`t turn on
It may sound weird but check that the motherboard battery cell is charged (the CR2032 coin battery). Some motherboards wouldn't power on if the battery is completely empty. Also clear the system setup via the jumpers on the board.
Try booting up with no graphic card installed and using the onboard graphics (if the board has a onboard GPU).
Aug 23, 2008 | Intel Motherboard
Open Questions:
Have A Non Responsive Touch Screen. Can I Recover My Data? These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With Online Cloud Backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a Computer Data Backup search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Business Server Data Backup some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 21, 2018 | VIA Computers & Internet
See all Dell XPS M1330 13.3" Tuxedo Black Laptop Computer. Questions
Dell XPS M1330 13.3" Tuxedo Black Laptop Computer. Sleek, Sophicated, and Truly Portable Laptop. Int... PC Notebook Logo
70 people viewed this question
Alun Cox
