Question about Edirol PCR-50 Keyboard
Edirol PCR-50 wont output any data for most keyboard keys
Almost brand new PCR-50. All control knobs, buttons, and sliders work fine and output data. However, only one key, (the very highest on the keyboard) flashes the data light when struck. No other key seems to work. Can't play any other keys into my Midi software. They just don't respond. Can anyone help??
Yes people it can be fixed by yourself at home, cheaply and easily. I’ve got an Edirol pcr-80 & prc-a30. Both have had intermittent key troubles and keys that just don’t work anymore or low/high level compared to other keys. These problems seem to start after a year or so. I’ve paid hundreds of dollars getting them fixed until I tried this on a whim. The contacts under the keys are a carbon-based contact so cleaning them with metho/alcohol just dries out this carbon. Some people say cleaning them with a pencil easier helps and it can do slightly but not properly. What you need is “Graphite Powder”. (Link for a picture of a appropriate product – just cut and paste it in your Internet heading bar, or Google image search graphite powder…)
http://images.google.com.au/images?hl=en&source=imghp&biw=1024&bih=1080&q=graphite+powder&gbv=2&aq=f&aqi=g1&aql=&oq=&gs_rfai=
Graphite powder is a dry fine powder that is conductive and perfect for the job. You can purchase at any locksmith – maybe a good hardware store, and it is sold as “non liquid lubricant for locks and machinery.”
All you need to do is unscrew the case, remove the springs that hold the keys in, remove the keys. (White keys first then black keys. Keep in order.) Peel off the rubber strip under the keys and turn over so you can see the little carbon nipples that touch the circuit board. (2 for each key) Pour a little power out on a sheet of paper and use a cotton tip bud to apply a little powder to these. Now apply a little to the carbon contacts on the circuit board where the little nipples touch. Do all this with your midi keyboard plugged in to your computer/synth etc so you can hear how you’re going with getting contact before you put it all back together. You might get a key or two going off when doing this because the graphite power is making a continuous contact across the circuit board. Just blow/lightly wipe away excess to stop this but you want to leave all the contact points evenly (if slightly) coated. Try touching the rubber strip contacts with the circuit board contacts to see if you can get a sound. This can be a bit tricky to line up and get an even contact. This sorts its self out when everything is back together.
Now put back the rubber strip. I used I tiny screwdriver to help push the rubber guide back in the holes on the circuit board. Now put the keys back (black first – with the short springs then white keys with the longer springs) screw the case back together and let me know how you went.
This I think will dry up again in time but if you get a good bit of use out of it you can just do it again… For free…
Garthy.
Posted on Sep 01, 2010
Windows 7 64 can not install the driver
Windows 7 64Bit requires signed drivers. Try looking on vendor's website otherwise I am afraid you need to either get a new controller or disable this requirement (not supported by MS)
Jun 07, 2012 | Edirol PCR-M30 32 key USB MIDI Keyboard...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Where can i buy the install disk for a edirol pcr-30
You can download the installation driver and software from manufacturer's support website by clicking this link
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=PCR%2D30
Hope this solves your problem. Thanks for using FixYa
Feb 17, 2011 | Edirol PCR-30 EDRPCR30 Keyboard
Edirol pcr 50 dont know how to work
Dont forget that the PCR50 is a Midi controller and as such has no "sound" of its own. You must have Midi compatible player or composer type software (like Reason, Cakewalk, Sonic, etc) to link up to the PCR50 to get any sound.
May 12, 2010 | Edirol PCR-50 Keyboard
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
Would USB alone support they keys to work?
try this
get the manufacturers web page up for that key board, find the down load for that model and your operating system and down load the software and driver
to make sure go to control panel > keyboard , right click to get properties and click on compatibility tab
click box and high light your operating system and apply
regardless if usb ( plug and play -PNP) or wifi it still needs drivers and you cannot rely on Microsoft for having the latest drivers
Dec 04, 2017 | Edirol PCR-30 EDRPCR30 Keyboard
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Edirol PCR-50 for mac OS X v10.5
Yes it is. I have one and have used it on mac OSX from 10.2 to 10.5.
Oct 16, 2008 | Edirol PCR-50 Keyboard
Replacing Key Contacts
I have a PCR-30 here that has developed several dead keys over the years.  I took the thing apart to clean the contacts and see if I could improve things -- unfortunately, it had the opposite effect, and I was left with only a few keys that *did* work.
I have since found a solution though, and now have a fully-functioning keyboard once again!
You'll need a tube of pure, dry graphite powder (only a couple of bucks from your local auto-supply shop), a tiny craft paintbrush, and a willingness to take your toy apart :)
Open the PCR up, and remove the springs holding the keys on.  I used a slotted screwdriver to jam into each spring, and lift it off the hooks.  I'd suggest keeping the keys in order to make it easier to put back together.
Now pull off the grey rubber contact sheets.  Clean out any dust that's under there, but don't be too abrasive or use chemicals.  We want to keep the existing contact material intact.
Put a little graphite powder in a small dish.  You won't need much.  It may seem a little clumpy, but it's actually extremely fine.  So fine, in fact, that if you smear it on your fingers it feels greasy, despite being completely dry.
Dab your brush in there to break it up, and get the brush well-impregnated.  Paint some powder on each of the contact surfaces both on the board side, and on the back of the grey rubber sheet.  Be careful not to connect the spaces between the contacts on the board... graphite is highly conductive, and you don't want an always-on key.
As you smear each contact with graphite, you'll notice it become a little shinier if you look at an angle.  You'll also get powder spattered around places, but don't worry.  Just blow off the excess.
Once you've done all of the contacts, place the rubber sheets back on (this can be kind of a pain, getting all the pegs back in the holes.  Hook it up and give it a test (just use your fingers to push the rubber pads), and repeat the process for any keys that still aren't working.
Once they're all back to 100%, replace the keys and reassemble.  You're good to go!
-Ben
Mar 18, 2008 | Edirol PCR-30 EDRPCR30 Keyboard
Edirol PCR-50 Keyboard Logo
919 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
