Question about Bosch Classixx WFL 2066 Front Load Washer
Where can i buy a cold water relay switch for a Bosch Nexxt 500 series washer? Water is leaking from there.
    Problem Solver:
  • 4 Answers
Appliancepartspro.com. I use them all the time there the best.
Super Fast del very helpful good prices. Sometimes a video on how too I ve Been using them for years. Can't say enough good things about them. Give em a try!!!
Posted on Jan 27, 2015
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about how to buy appliance parts online...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on May 29, 2010
I replaced the original leaking washer hoses on my Nexxt 500 machine with metal ones. On quick wash cycle, water does not flow at all. Does the Bosch Nexxt 500 require OEM hoses only for water flow?
A hose is a hose is a hose. Type of hose won't make any difference.
If you can, try to do a wash cycle that allows you to see if both the hot and cold water are working. You may have loosened a wire connection to one of the valves for the hot or cold when you connected the new hose, or possibly there was something inside the new hose that is now blocking one of the valves.
Aug 17, 2016 | Bosch Washing Machines
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexxt 500 plus/water won't enter
H i there.....have you checked that the door switch is locking when appliance is switched on....if so most likley cause is faulty control module....
regards Sir Galahad
Aug 20, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Oct 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Classixx WFL 2066 Front Load Washer Logo
110 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
