I have an HP Photosmart C6150 All-in-One and when I try to print, the paper gets stuck every time. It looks like it doesn't feed all of the way through, The paper kindof curls under instead of over and causes a paper jam. The printer doesn't recognize it as a paper jam, it just says load more paper.
  • 903 Answers
If the paper is curling, it may because of humidity. Try flipping the paper over in the tray (so it's upside down). Does that make a difference?
Posted on May 29, 2010
Why does my HP Photosmart C6150 All-in-One only prints/scans full black page
Open the scanner cover and check on you to copy double-check scanner moves when the light comes from the scanner and see if it sees the glass as if it would be messy to be opened and cleaned
Jul 22, 2014 | HP Photosmart C6150 Wireless All-in-one...
Hp Photosmart c4750 all-in-one printer; paper won't feed, with the power on and everything.
Check where you feed the paper you could have something in the way i remember one time i had a ecig charger stuck in mine it did the same thing more than likely something fell in there.
Oct 20, 2017 | Office Equipment & Supplies
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
My c6150 HP will not print boarderless, leaving about an inch blank as it exit the printer, what have I screwed uo ??TIA PHIL
If you tell it you are using HP paper it will do that, HP has a tear off tab at the bottom that doesn't get printed, you may have to choose another paper in the printing preferences.
Nov 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C6150 shows an "Out of Paper" message. I have repeatedly removed paper and added it back, message still shows & it won't print
Dear sir your printer problem is paper sensor when you stay paper then paper switch is open but this printer paper switch lever is broken or displace please chack it then solve your problem
Jul 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6150. Rollers do not pick up paper
Remove the rear cover a reallly scrub the black rollers with isopropyl alcohol. Scrub HARD
Jun 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper feed will not work
Remove the access door in the rear and clean the black rubber rollers with alcohol.
Feb 21, 2009 | HP Photosmart 2575 All-In-One InkJet...
Problems with the paper feed.
I had this same problem with my HP 2575 printer. I complained very strongly to HP and they sent me (free of any charges) an HP Paper Cleaning Kit. Took about 20 minutes to clean and rough up a rubber feeding roll in the printer. VOILA-- printer has been feeding perfectly for over a year. A friend of mine with the same printer,had the same problem. He used it and now has no problem. You will have to get after HP and have them send you the Kit. Hope this helps you out. SANS
Nov 20, 2008 | HP Photosmart C5280 Printer
108 people viewed this question
k24674
jasbo
jasbo
