Question about Toshiba 52HM95 52" HDTV Projection Television
My power light turns on but my screen will not show up
  • 94 Answers
Check the DLP lamp. It is located at the left side of the television. If it has a white cloud on it or if it is shattered then you will need a new lamp. Directions to check the lamp are in your owners manual. If you no longer have the manual go to toshiba.com and type in the model number to get it.
Posted on May 29, 2010
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
My lenovo ideapad y560's monitor won't open. the monitor is pitched black.
Hi thelzy,
I see that your Lenovo Y560 is having issues showing no Video, you mentioned that you only get a Black screen when booting.
I am assuming that there is still power on the machine but no video at all, Just to ask do you still see the Lenovo Splash screen? if not then we can try doing a power cycle on the machine.
* Remove the battery on the system unhook the Power Cord/AC adapter as well then press and hold down the power button of your Y560 Laptop for about 15 seconds then let go.
*After Doing the Power Cycle connect the AC Adapter again but leave the battery out for the time being then turn the compute ON, check to see if it will show the Lenovo Splash screen if it does then we're in progress and should show windows Loading up on the LCD screen.
*If it does not show the lenovo Splash screen then most probably the BIOS screen never showed as well on the issue.
*Connect the battery back n the machne turn it ON again check if it will show anything on the screen, if not then see below.
*We can try connecting an external mnitor to the system using a VGA connection it should show us the Screen on the external monitor if not then it means that Windows as well is not booting on your Laptop.
*Check the indicator Lights on the Laptop, one of the Lights will be a cylinder icon on the Laptop check if there is any activity from that light if there is no Light or any avtivity to any of the indicator lights then your Y560 is having issue with the Motherboard.
I hope this info Helps.
Have a nice day.
mvincentc
Apr 21, 2011 | Lenovo IdeaPad Y560 Notebook
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Proton
Jul 12, 2009 | Computers & Internet
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
PS2 slim powers on, but nothing shows on the screen
have you checked that the av cables are pluged in properly???
Oct 09, 2008 | Sony PlayStation 2 (PS2) Console
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Toshiba 52HM95 52" HDTV Projection Television Logo
972 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
