Question about Canon EOS 400D Digital Camera
Cannon error 05
Canon error 05 comes in EOS 400 D flash not operating
    Sniper:
  • 54 Answers
Error 05 means that something mechanically prevents built in flash to pop up. Ensure that nothing is blocking flash. Switch in P mode and press flash button to pop it up. If it does not pop up - try _gently_ to help it to pop up. If you succed in popping up the flash - check it for any dirt with can prevent flash from popping up.
Posted on Jun 18, 2010
    New Friend:
  • 94 Answers
You can manualy open top cover and you can see there four screws open it up and there is left side one silver big screw take out and clean it with fiber pen and put it back same way everything and clean up and front cover top edge slightly push out. if working then good other wise you need to replace top cover,
Posted on Aug 02, 2010
SOURCE:
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Error 05 on canon eos 550 d
tryed everyones sugestions for erros 05.3 clicks but non worked until i took the flash cover of by takeing 2 screws out very easy and then loosenedthe screw with the spring until flash moved freely
Feb 01, 2012 | Canon EOS 550D Rebel T2i Digital Camera
Canon eos 350d error 05, keep switchin on and off to correct but keeps reoccuring
is it also trying to release the flash when this happens? If so try and manoeuvre the flash a little by hand as it try's to open. once it opens its usually fine thereafter.
May 04, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel Error message E05
Go the the Canon support website and enter your camera model. If there is something you can do, it's there.
The E05 error says the lens is jammed or not working correctly. My guess is you need to take it to Canon.
This happens if sand gets in the lens or the camera is dropped.
Apr 21, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D flashes error 05 and flash won't pop up
I had the same problem but found that manually popping the flash up about 10 or 12 times restored the auto pop-up function.
Hope that this helps
Jan 13, 2010 | Canon Rebel XT / EOS 350D Digital Camera
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Oct 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 05
Hi, Mark here to try & help.
Error 5 on a cannon slr means flash did not pop up.
This is not unusual even on there high end slrs.
Have even seen it on new cameras out of the box.
Fix
  1. Push flash pop up button & gently assist flash to open.
  2. Clean inside flash compartment be very gentle, use warm soapy water on the end of a q-tip (do not soak q-tip just dampen), clean moving parts as well.
  3. let dry then remove any lent or cotton that might be left behind (wrapping tape works well for this just dab).
  4. Apply wd-40 with q-tip to moving parts again do not soak q-tip you just want a light coating .
  5. You will still have to do this again on occasion, & it will only help with fewer errors, you will still get them just not as often.
Cannon will have to redesign this flaw, but do not hold your breath, this is something that has been happening for awhile. You can send it in but still have same problem when it comes back.
Know that is not all good news. But it should Fix ya! & you have some idea of what is happening.
Please rate. Good Luck! & Happy Shooting!
Mar 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D Digital Camera Logo
758 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
