Question about Sony Playstation 3 (PS3) Console
What is the WEP Key for a wireless PS3 on a 2wire782 ATT wireless system?
    Problem Solver:
  • 11 Answers
What ever the person set the password as.
Posted on May 29, 2010
2wire782? on at&t? wait...do you live in santa cruz anywhere?
Posted on Jun 23, 2010
HOW DO I CONNECT MY NEXUS 7 TO MY WIRELESS ROUTER
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 12, 2012 | 2wire HomePortal 1800HG Router...
Tip
How to set up WEP on Linksys Router
Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
Question
How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
Answer
Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
To setup WEP Wireless Security on your Linksys router follow the steps below.
Setting-Up the Linksys Router to use WEP
Step 1:
Access the router’s web-based setup page. For instructions, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
Step 3:
Look for SecurityMode and select WEP.
For Wireless-A Settings:
4439-001.pngFor Wireless-G Settings:
4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Look for the Encryption drop down menu and select 152 bits.
Step 5:
Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
Step 6:
When you click Generate, the result will be a string of random characters.
Step 7:
Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
4439-005.pngStep 8:
Copy Key1 since 1 was selected under TX Key.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 9:
Click 4058-005.jpg.
© 2010 Cisco Systems, Inc. All rights reserved.
on Feb 26, 2010 | Computers & Internet
How do i secure my belikn from outsiders using it
Enable wireless security on your router, so that other people will not be able to connect to your network.
To enable wireless security, access the setup page of the router through a web browser. Type 192.168.2.1 in the address bar.
By default, leave the password blank.
Once in the setup page, go to Wireless. Take note of your SSID. Then go to Security.
Select WEP or WPA, depending on the operating system and capabilities of your wireless computer. If in doubt, you may use WEP since it is the legacy wireless standard.
You can enter your WEP key manually by typing in the hex WEP key manually, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase.
Make sure to take note of the WEP key because you will be needing this for your wireless computer.
Click Apply Changes.
On your wireless computer, view the available wireless networks, select your SSID, then type the WEP key.
I hope this helps!
May 11, 2010 | Belkin (F5D9230-4) Wireless Router...
I want to encrypt a wireless network with wep
Question
Answer
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
4439-005.pngStep 8:
Step 9:
Click 4058-005.jpg.
Feb 26, 2010 | Linksys Wireless-G WRT54G Router
Need my wep key from my 2wire gateway from att
Ok, the WEP key is generated during the Router Setup. IF you do NOT know it. You WILL have to set the router up again, this time taking note of the Key, I always copy paste to a notepad document while I am doing it. That way you can copy paste into the Client settings saves all that typing. So that's what you will have to do.
Feb 24, 2010 | Belkin 802.11g Wireless Desktop Network...
Need wep key code
The wep key is set by the system admin when the router is installed, contact the systen admin to get the wep key.
If you forgot it you have to reset it but logging into the router's setup through a browser by typing its IP address, then going to Wireless Network Security and changing the WEP key.
Hope this helps,
Cheers,
Jan 06, 2010 | D-Link AirPlus DI-524 Wireless Router
What is a wep key, and where will i find it, for setting up xbox 360 thanks
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
Dec 25, 2009 | Video Game Consoles & Games
How do I get my WEP key from my router
You normaly generate your own WEP key. A WEP key is a password to log in to your wirless network. Log into your router go to wireless settings some were on this page you will see WEp key gernate password phrase and like Key 1 , Key 2, Key 3 anyway go to Key 1 type in the password you want and click save settings..... Dont forget your password or you will half to hit the reset button on your router
Sep 20, 2009 | Marconi Systems Marconi Router
Att 2701 hg-b modem
Hi , the 2701HG-B by default uses the last 3digits of the SN number as the SSID and the 10 digit number in brackets as the WEP key to access the user interface of the 2701 type in the address bar of your browser 192.168.1.254 and push enter, to access the interface program you will need to run the system set up and you must know the keycode from your service provider and the username and password
Jan 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I am visiting my aunt, she has att broad band with wireless, I put the wep key in and it gives me limited or no connectivity. It gave me a 168 address so I manually put in a 192 address, got rid of limited...
First take off WEP.
Next, ensure DHCP is enabled on router.
Don't set a manual IP address in computer, it should auto detect.
You probably have the WEP key wrong
Use the HEX WEP key in windows, do not use a pass phrase.
Aug 17, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
212 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
