Question about Car Audio & Video
How 2 insall emergency parking wire on dual xdvd700 in 97 deville
How do you install the emergency parking wire on a dual xdvd700 multimedia receiver in a 97 cadillac deville
  • 1,871 Answers
Hello! A toggle switch on the wire with the other side to ground...If you have the switch On when you turn the car on...Wait for Dual to boot-up...Then Off and back On...If it's Off when you turn the car on...On/Off/On...You might try permanently grounding the wire first before installing a switch...
Guru..........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on May 29, 2010
Dumb question, How do I release parking brake on 88 DeVille? Thought there would be a lever somewhere but I can't find one Also, I've been told it needs premium gas. Is this true?
You have a car that was built withh all the bells and whistles you know. The emergency parking brake is not so sophisticated at all. Cadillac installed a vacuum pod to the release actuating lever which conjoins to the shift bowl. When you aplly your foot on the brake to shift the emergency brakes will release automaticly. If it will not release, the vacuum pod is at fault & will need a replacement. They are inexpensive at any Cadillac dealerships parts department.
Jun 20, 2010 | 1988 Cadillac Sedan DeVille
Parking brake stuck.
if you look at the pedal for the emergency brahe there is a small lever that will allow you to by-pass the vacuum operated release,check for vacuum at the hose that goes into the release
Apr 13, 2009 | 1994 Cadillac DeVille
How do u bypass the emergency brake sensor on the kenwood dnx8120?
exactly, just connect the parking wire to a ground source and your problem is solved. This hack also allows use of the nav. while the vehicle is moving.
Apr 04, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
I pushed my emergency brake down and now i can't get it back up
try putting the car in drive then back in park. should release brake.
Jan 20, 2009 | 1992 Cadillac DeVille
Dear Sir I installed a pioneer avic-f900bt as instructed in the manuals.When I m parked the unit works ok but as soon as i drive it starts switching off and on again.I did install the handbrake wire too.
I believe this is a safety problem to prevent distractions to the driver since this unit is installed in eye sight of the driver. Parked position is fine because the parking brake is on signifying you are stopped. Once moving it should turn off multimedia functionality. Try grounding your parking brake cable to think it is always on :)
Jan 10, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
