Question about Kohler K-15076-P-7 Coralais Decorator kitchen sink faucet with matching fin
Need to dissasemble the faucet...
I removed the hex screw on the handle, but can not remove the handle!
    Scholar:
  • 81 Answers
Go to http://www.kohlerserviceparts.kohler.com/ and get a parts explosion for your faucet. It should help immensly.
Posted on May 29, 2010
Cannot remove 1/8" hex nut on handle. I am trying to replace valve control due to a leaky faucet. Nut seems frozen. Mel
A faucet handle? In Automotive?
If you mean a sink faucet, what brand? Is it single lever? On some, it's not a hex; rather a narrow slotted screw.
Oct 15, 2016 | Cars & Trucks
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How do I remove the cartridge on this faucet?
    To remove the cartridge from your faucet assembly, first use a hex wrench to loosen and remove the screw from the base of the handle. Then, pull the handle up off thefaucet assembly. Unscrew the dome and remove it. Remove the connector screw and lift off the adaptor and connector assembly.
Dec 03, 2015 | Plumbing
How do I remove faucet handle
Depends on the type of handle. If you have both hoe and cold handles they can usually be removed by prying off the cap that has "C" or "H" on it. Under that there will be a Phillips screw.
Single handle have hex key set screws on the back or under side. Use can back that out with an "Allen" wrench.
Feb 20, 2015 | Jado 842803100 Hatteras Chrome Widespread...
How to replace hansgrohe M2 cartridge
First you will need to tighten the set screw all the way back in. The use your 4mm hex wrench to turn the screw 4 complete turns counter clockwise. Then remove your hex wrench and the handle should come off. There will be a dome shaped cover with blue and red indicator marks. This will simply pull off the cartridge nut. It is held on by o-ring tension only. Once removed you will see the large hex head of the cartridge retainer nut. Loosen this nut and the nut and cartridge will come out of the faucet. Don't be alarmed if your new cartridge is smaller than your old one. There has been a design change in the cartridge so it will fit smaller bodied faucets but will still replace the older thicker cartidge. If you need any further information feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be glad to help.
Aug 04, 2012 | Hansgrohe Plumbing
How do you take a Hansgrohe 6566000 metro pull out spray faucet apart?
There is a hole in the handle for the 4mm hex wrench to fit into. You will need to put the handle up in the "on" position. Then the hole will line up with the set screw and your wrench can push straight into the set screw. Rotate the set screw counter clokwise 4 complete turns. Then remove the hex wrench and the handle will lift off the faucet.
Jul 30, 2012 | Plumbing
How do you remove a shower faucet faceplate that does not have a screw. No idea who the manufacturer is.
remove the handle,, there should be a small hex head that you need to remove, once thats done, the flange right behind the handle can be unscrewed which holds up the faceplate ( some flanges cover screws to do this, others Just unscrew since your not sure of the model,, thats a good start to your problem
May 08, 2011 | Delta & Single Handle Shower Faucet
Leak in the faucet handle
Here is a link to the manual,Page 2 and 3 has the info you need.
Please take time to rate this a fixya
May 20, 2009 | American Standard 4175.200.002 Colony...
How do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Kohler K-15076-P-7 Coralais Decorator kitchen sink faucet with matching fin Logo
313 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
