Question about Bryant Heating & Cooling
Our Bryant air conditioner that we bought a year ago started leaking water yesterday but was still working. It isn't working at all today even though the thermostat says "on". Is there a way to reset it?
  • mopar440man May 29, 2010
    it is frozen. have you changed the filter.
    President:
  • 949 Answers
These symptoms usually indicate a problem with the drain. If the drain for the evaporator is restricted it may leak, if it leaks enough it will activate a float switch that turns off the air cooling unit.
The first thing you need to do is locate the evaporator, depending on where you live and what type of home you have it will be in the basement or the attic most likely. There will be a pan under the cooling coils, if in that pan there is water then your drain for the cooling coils is plugged. Look above that pan for another drain line that is the one you need to clean out.
In the pan that has the water you will find some type of float or water switch that is keeping the A/C from coming on.
Send me a message here if you have questions.
Posted on May 29, 2010
Leaking water
PUT hose and check other end
Jul 26, 2014 | Bryant Heating & Cooling
Our Bryant heat pump is leaking water from the base. This seems to be occuring on particularly hot days when the air conditioning has been turned to a lower temperature.
The drain pan for the evaporator needs to be checked for cracks & make sure the evaporator is centrally lined up to the pan. Sometimes condensate shield are installed to manage the water blown off the evaporator coil. Generally with the evaporator housing open, check any signs of where water has been traveling ie rust lines or calcium deposit lines to determine were the water is coming from.
Jul 18, 2011 | Bryant 463AAC005BA Air Conditioner
I keep getting water leaking out of my bryant heat pump (indoor unit) in the summer when the wheather is very hot and humid for a long time. I suspect there is too much ice buildup and it is dripping...
If it is freezing up then it is for sure dripping outside the catch pan.. Have you been able to take the front cover off and see ice on the coil.... ?
Aug 20, 2010 | Bryant 463AAC005BA Air Conditioner
Can u plz tell me what wrong with my air
Mary it sounds like you just need to take another look at the drain hose and where it connects in the unit. Also make sure the hose isn't kinked or stopped up. If there is a pan inside that catches water make sure the hose is lower than the pan. Hope this helps.
May 24, 2010 | Danby DPAC8020 Air Conditioner
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
Leaking antifreeze on the right side new water pump and hose to on over a month ago
you changed the water water pump because it probably overheated. you might have a broken head gasket and combustion pressure is entering the cooling system
May 21, 2009 | 1995 Ford Windstar
Heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Jan 18, 2009 | Amana PTH123B25AJ Heat Pump Air...
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
External water tank
Dear ziba1--posted the same problem two days ago and it doesn't appear to be on the site yet. Anyway, picked away at this again today (literally took the machine apart) and found the problem to be a clog in the drainage system. This explains why your external tank will not fill and why there is a leak--the drip tray under the compressor is not draining due to the clog in the drainage system. I fixed this simply by taking a narrow device and gently scraping out the drain hole of the drip tray (which is located just below the compressor...the compressor is located on the same side as your air filter). After successfully cleaning out this drain, I proceeded to flush the water out thoroughly with water. Give it a try--worked for me. I had all but given up and had already set up an appointment to have it serviced. Cheers
Jul 25, 2007 | Danby DPAC8399 Air Conditioner
Heating & Cooling Logo
284 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
