Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor won't come on. it blinks with a light and then goes off.
The monitor would start blinking on and off. If I turned off my computer it would fix it for awhile. but now that doesn't work either. The monitor power light blinks on and off as well.
  • 11,361 Answers
You have shorted transistors (c5707) in the inverter circuits, also need to check for poor solder joints and the tuning caps in the inverter transformers driving section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd. www.lcdrepair.us
Service manuals: http://elektrotanya.com/?q=showresult&megnev=dell&megnev2=%20e173fp&kategoria=&kat2=all
Posted on May 29, 2010
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Computer monitor problem
ok the problem is not the monitor it is either the cable checke each end for bent pins inside or the computer you are trying to use
Jan 13, 2018 | Computers & Internet
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
620 people viewed this question
Alun Cox
