Question about Xerox Phaser 7750DN Laser Printer
Phaser 7750 wont run "Service Diagnostics" (or print anything!)
Was working fine until I cleared a jam. Restarted machine,
and LED indicated "ready to print" but nothing printed. Job
leaves the print spool, and "processes data" briefly but no printing. It will not print locally either ( jobs stored in memory or Xerox reports) It doesnt recognize any problems..as a test,i took out the fuser and restarted without it, but it still says ready to print. It doesnt know the fuser isnt in the machine! I am unable to clear NVRAM and Engine NVRAM, and when I try to enter Service Diagnostics..it wont get past cycling at "initializing Service Diagnostics V.0.0" Yet I can move around the LED panel as if all is fine. Starts up fine, like its good to go, but its not.New firmware did not help.. HELP!
  • 3,866 Answers
Big time issue, the brain of the printer is not seeing the rest of the printer so guess what? the jobs are not getting printed. This will cost a arm and a foot to replace trust me. $295 bucks both parts and labor. The whole printer PCM will have tome be switched out, that is printer control module (the brain).
This si all evident because you said you took out the fuser try ed to print it says it was ready, There is zero communications with the rest of the parts here and that is my diagnosis.
please do click the accept button for my efforts.
Posted on May 29, 2010
  • 1 more comment
  • joleary57 May 29, 2010
    Thanks, can you tell me more about the 295.00 parts and labor? I didn't quite understand.
    also, is your answer based on experience with the Phaser 7750,
    or just common to a variety of laser printers?
    would the PCM be the same as the "image processor board?
    I see it listed on ebay as XEROX PHASER 7750 IMAGE PROCESSOR BOARD 650-4306-01
  • Grand Canyon Tech
    Grand Canyon Tech May 29, 2010
    Yes its my experience with this unit. $295 is a estimate not actual as it can be lower where you live.
    Adn the ebay thing seems liek it may be the part number, your looking for.
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Phaser 860 Phantom Jam Won't print until jam in
There is a solenoid on the transfix assembly that has a tendency to "stick" in the open position, causing paper jams at the exit. The Solenoid is located on the right side of the machine, at the top area in the middle. You can test it with your fingers to see if it sticks in the up position. If it is, simply clean the sticky residue off both metal surfaces with alcohol and it should return to normal operations.
Aug 26, 2013 | Xerox Phaser Office Equipment & Supplies
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
"Print Error-Contact Service; Report Fault 7-401"??
Reset the Tray 2 feed counter within Service Diagnostics as follows:
1. Enter Service Diagnostics (back arrow botton with the "i" button soon as you turn it on) and scroll to NVRAM Access and press OK
2. Scroll to Reset CRU Life Counters and press OK. The display will show the status of all CRUs. Press OK until the Reset Counters menu is displayed.
3. in the Reset Counters menu select Yes and press OK.
4. Scroll to Tray 2 and press OK.
5. Exit diagnostics.
That's what worked for me I called a company called Iteminc they gave me the instructions and they told me to :Replace the tray 2 pick, feed and separate rollers before it starts jamming soon. www.iteminc.com is their website good luck give them a call if it does not work.
Mar 11, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 7750 Fault 9-913
Use the following procedure to troubleshoot Error Codes 009-910 through 009-913
1. Check the installation of the Print Cartridge. 2. Clear the Tech Rep Fault for errors 009-910 through 009-913 (see instructions below). 3. Try changing the indicated Print Cartridge. 4. Check for an open wire or poor contact between the Print Cartridge and the Engine Control Board. a. Yellow, J-151 to J-405 b. Magenta, J-152 to J-405 c. Cyan, J-153 to J-405 d. Black, J-154 to J-405 5. Replace the engine control board
NOTE:  Before troubleshooting for an open circuit (Step 4) or replacing the Engine Control Board (Step 5), clear the Tech Rep Fault for any of these codes first using the following steps: 1. Enter Service Diagnostics. 2. Highlight NVRAM Access and press OK. 3. Highlight Clear Tech Rep Faults and press OK. 4. Highlight link codes 009-910 through 009-913 and press OK.
Hope my info solves your problem..... Thanx for using fixya......
Oct 24, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7750DN Laser Printer Logo
122 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
