Question about Frigidaire GLTF1670A Front Load Washer
My washer has no spin cycle. I replaced the belt
  • Frigidaire Master
  • 1,527 Answers
Hello any spin problems can be down to the module board usually sits down the side of the washer got wires coming off it. the transistor burns out on the board it would be better to get a reconditioned board also make sure the washer is not on rinse hold i'e the button not pressed in good luck
regards
shaun
Posted on May 29, 2010
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
THE LAST SPIN ON A FRIDGEAIRE WASHER DOE NOT SPIN HARD ENOUGH TO PULL THE WATER OUT ANY MORE ITS A XC24017503 MDEL NUMBER 10 CYCLE
Frigidaire washers have a special belt that loses its ability to grab over time. NO other belt will fix your spin problem but the original Frigidaire belt. Fortunately for you, it is quite easy to replace. Also remember that the spin cycle is not for draining water, it is for wringing residual water from clothes while the pump is running.
So, your actual problem in the spin cycle itself.
Another factor to consider is that the bottom tub bearing on many frigidaire washers tends to rust and degrade over time producing a roaring noise. If this has happened to you, replacement is problematic and expensive, if not, you simply need a new belt.
Mar 05, 2010 | Dishwashers
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer does not spin in the spin cycle.
if it works on washing cycle and only not works in spinning cycle then you not need to see the belt it is the same. check the "no spin" mode check draining filter
Jun 06, 2009 | Kenmore Washing Machines
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Frigidaire GLTF1670A Front Load Washer Logo
100 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
