Question about Dynex DX-LDVD19-10A LCD TV
My 19" Dynex LCD tv Picture has an odd tint-Service menu problems
Ok, my nephew got ahold of my remote and somehow got into the service menu and screwed with some setiings. i believe he used the auto color feature and now the TV shows everything in a blueish tint. I use this TV as a PC monitor for image editing so i need the colors to be correct. All other inputs (HDMI, AV, Ect) display normally. any ideas besides paying cash to have it repaired?
usmcdcf
  • 5 Answers
SOURCE: Dynex 19 LCD
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
Posted on Jan 11, 2009
aparsons89
  • 40 Answers
SOURCE: No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
Posted on May 13, 2009
jamielwright
  • 75 Answers
SOURCE: Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Posted on Jun 01, 2009
  • 56 Answers
SOURCE: Horizontal lines and color problems?
this could be a format issue. When you change the channel do the lines go away ? If so try to go into the cable box (assuming you have a cable box) and reset your formats and exclude the format causing the lines.Make sure if your using component cables all colors match up.If this does not fix it replace your component cables/hdmi.All else fails unplug your TV wait 5 min. and plug it back in. Hope this works for you.
Posted on Jul 08, 2009
toddthetvmd
  • 101 Answers
SOURCE: Dynex 37" LCD TV bad color
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
Posted on Oct 26, 2009
I have no remote for tv and picture I get is not full screen. How do I use menu to get full screen picture?
Comcast remotes generally do not allow you to use the menu option for your TV. Check the Dynex website by entering your model number to find the manual for your tv.
Dec 30, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Cant get the tv back to channel 03 called dish network tehy couldnt help me said i had to contact u guys to tell me how to do this its a dynex 19in lcd tv
Have you tried programming the remote to the TV? We don't have codes for a Dynex however, this link will take you to what's called a power scan this should help.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Daniel Busa
DISH Network Customer Service
Dec 12, 2010 | Dynex DX-LCD19-09 19 in. LCD TV
I need a code for dish network i just bought a tv dynex 19 inch tv lcd
Hello, I hope that this has been resolved for you already, but if not, pleases follow the link below, and that remote will be working with the tv in no time!!!!!
Becki Barned
Nov 22, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
Have a lcd 42 dynex picture dark
Have a 40" Dynex LCD TV...Has been workin ok but i just turned it on today and pics are dark and yet all pics settings are ok. Pics are still dark even when i increase brightness from menu.
May 18, 2010 | Televison & Video
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Televison & Video
Dynex DX-LDVD19-10A LCD TV Logo
181 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
