Question about Proform 695 LT Treadmill
My Proform 695 LT runs fine when Iam not on it but when I get on the machine it starts pausing in between running or even a slow walk
    President:
  • Proform Master
  • 832 Answers
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 29, 2010
Need new proform treadmill 695 lt motor
go to www.fitnessrepairparts.com and God bless youMeasure the input voltage to the motor if there are voltage , the motor is faulty. mesuare the output voltage from control motor board, if there are NOT the control board is faulty.see the block diagram.God bless youac4388bf-31eb-4f87-ad43-9c0c10d012bc.gif2e4eb1b3-5071-4c47-9080-6b4922436639.jpg
Apr 05, 2013 | Proform 695 LT Treadmill
3 beeps on start up
1) adjust the REED switch see the diagram, clean it, and tight the plug very well
2) adjust the speed sensor see the diagram, clean it, and tigh the plug very well.
3) Try after you did the adjustment to RUN the software calibration for diagnostis, troubleshooting, and fix it.
see the diagram attached.
God bless you
9_26_2012_12_57_06_pm.gif9_26_2012_12_57_34_pm.gif9_26_2012_12_58_10_pm.gif9_26_2012_12_58_30_pm.gif
Sep 25, 2012 | Proform 695 LT Treadmill
My proform 685 LT treadmill will only incline and decline when turned on. It does this automatically. The belt will not run at all.
Run the software calibration for diagnose, troubleshooting, and fix it.
2) LUBE the deck belt, this happen by lack of maintenance, maybe you have the deck worn.
3) lube the rollers bearing too
4) measure the input voltage motor, if there are the motor need repair.
5) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
see the diagram
Jul 23, 2012 | Proform 695 LT Treadmill
I'm considerin buying treadmill from canadian tire poform 695 can you give me a device on this brand .
if you really want to know what people is saying about this machine go to the main site of the 'manufacturers and see the blogs, i'm pretty sure the constant posting of the customer's comments don't lie.
Apr 09, 2011 | Proform 695 LT Treadmill
Is there a weight restriction ?
It is not a restriction. It is a recommended limit of 300 lbs. See ProForm 695 LT Treadmill
If you weigh more than the limit, the machine will feel, and be, unstable. You could also harm the motor over time.
Dec 28, 2010 | Proform 695 LT Treadmill
Belt slips and somtimes stops on me while walking.
hi. if the belt slips and stops when your walking its a sign the you may need a replacement belt. and if you smell motor burning after you have been on for a while that is a sign that a/ you have no oil left and b/ your motor is slowley packing up.hope i have helped.
Nov 11, 2010 | Proform 695 LT Treadmill
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 02, 2010 | Proform 680 LT Treadmill
Code FF on a Proform 695 LT
Upper electronics have failed and will need replaced depending on how much you spent on the unit it may not be worth it. Go on iconfitness.com website go to customer service then replacement parts input manufacturer then Model Name
Apr 23, 2010 | Exercise & Fitness
Proform 695 LT Treadmill Logo
636 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
