I installed System Mechanic Professional, fellowed all instructions, now my computer has slowed down so bad, the initializing period of the start-up is taking about 10 minutes, freeze up after about next 15 minutes. what going on? Please reply, I need my computer to work!
    Scholar:
  • 50 Answers
Seems like the software program or something else might have messed up your registry settings.
When you turn on the computer, press F8 to get to a page with options for starting the Operating System. This only applies if you have Windows, preferably XP. Once there, select "Safe Mode with Networking". If you can get the computer to a point where you're able to use it, either run System Mechanic and have it undo the changes it made to your system, or run System Restore from Start -> Accessories -> System Tools -> System Restore.
If you use System Restore, select a point before you did the changes, but recent enough to where you won't mess anything else up.
In the future, be sure to carefully check what each part of the registry being cleaned controls... Too much interference can be bad!
Posted on Apr 09, 2008
SOURCE:
Can system mechanic coexist with norton security suite
Hi Jim,
Norton Security Suite Takes Lots of Space and Slow Down The System if you are using old version of norton security suite and please disable the background acitivities of norton its slow down the system takes the CPU Consumptions Power & yes System Mechanic Coexist with the norton security suite only if you disable the background processes.
Thanks & Regards
Bheshaj
Apr 19, 2013 | Iolo Technologies System Mechanic: Windows
It is stuck on pc health status gadget moveing slow never finshs
Same here. But you don't need to install the Health Gadget. Go back into the install option, and do not choose 'typical', but choose the alternative (the parts you want to install). It'll give you to option to unclick the 'Health gadget' option. Unclick it, and the System Mechanic will install. (The health gadget is just a visible reminder on your desktop, and is not needed)
Sep 17, 2012 | Iolo Technologies System Mechanic...
I get a 323-a error message when I am trying to instal sytem mechanic.
well this message does come up in many ways and to trouble shoot the problem have to know the OS, modem, and when the initial error occured, after downloading some new program etc.
Oct 03, 2010 | Iolo Technologies System Mechanic...
The iolo system shield would not update
This is gonna be Lengthy process.
First
Uninstall System Mechanic Professional
Open the Control Panel by clicking:
Start>Control Panel
or
Start>Settings>Control Panel
Open Add or Remove Programs.
Locate and select the entry entitled iolo technologies System Mechanic Professional
Click the entry’s corresponding Change/Remove button.
Follow the on-screen instructions to uninstall, restarting the computer as prompted.
Remove the System Mechanic Professional registry entries
WARNING: Using the Windows Registry Editor incorrectly can cause serious problems and may result in an inoperable operating system. Use Registry Editor at your own risk and discretion.
Click the Windows Start button.
Select Run.
Type regedit in the Open field.
Click OK.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Remove residual antivirus files
Close all open windows and restart the computer
Follow the same process to uninstall the System Shield also.
Reboot the PC after everything is over.
Then install System Shield First, reboot the PC after the installation and check if the update it working or not. Once its confirmed that System Shield's update is working, install the System Shield.
May 30, 2010 | ACDSystems System Mechanic with Bonus Iolo...
My System Mechanic Professional not is too good: "the component"iolosystenservice" is required for System Mechanic Professional to operate properly and could not be started please let me know some...
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
OR
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
Expand Software.
Expand Software.
Click Yes to confirm.
May 19, 2010 | Iolo Technologies System Mechanic: Windows
Have windows xp prof 3pack, takes over 10 to 15 minutes to get on the net. after awhile (hr to 3hrs) starts to freeze or slow down. I done it all, frag, cleaned, deleted, scanned. I have mechanic system...
if your download this prof 3pack take over 10 to 15 minutes you must becarefull to install in your computer, you better re-download through windows update again.good luck
Apr 26, 2010 | Microsoft Windows XP Professional SP2
Program won't start. Get message "the component IoloSystemService" is required for system mechanic to operate properly and could not be found. System Mech 9.5.6 is installed and looks good. Running XP,...
OR
Expand Software.
Expand Software.
Reinstall the System Mechanic Pro
Mar 06, 2010 | Iolo Technologies System Mechanic: Windows
Can't get out of safe mode
While booting ur system press F8 initially when system turned on you will get booting options .Select Normal and Enter you can able to boot in normal mode.
Oct 26, 2008 | Microsoft Windows 2000 Professional for PC
Open Questions:
Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}Avast tEcH SupPoRt pHoNe {@} {/1888499**5520-}
Oct 14, 2019 | Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
