Question about Car Audio & Video
Fitting a jvc head unit to a 1990 telstar tx5 does the yellow wire from car connect to yellow from jvc and does red access. wire from car connect to red from jvc. because have tried this nothing happening unless i connect red and yellow together from jvc and red and yellow from car.appreciate any help cheers.
  • 311 Answers
Get a voltmeter(multimeter) and check the voltage on the
red wire
and
yellow wire
(from the car)
when the car is turned off and when the car is on
one should be 0V when the car is off
and both should be 12V when the car is on
then you need to match that up with the radio using the manual
but im guessing that you dont have a manual so...
i want ot confirm that
when you connect red to red and yellow to yellow
nothing happens
try the oposite way
red to yellow yelolow to red
Posted on May 29, 2010
How to do valve timing on Ford Telstar TX5?
1994 ford telstar tx5 cambelt timing marks, when the crank shaft is t.d.c where are the arrows on the cam ment to line upto?
Sep 04, 2011 | 1996 Mazda MX-6
I'm trying to fit a JVC cd head unit into 51 reg corsa, have connected wiring but unit does not power up. help!!!
Make sure the red wire and yellow wire have 12 volts (may be as high as 14.4 volts) positive voltage & the black wire is grounded (negative) Also check the fuses on the head unit (usually on the harness) and make sure the speaker connections are not shorted before powering it up. Any blue wires from the radio should be isolated & taped off to prevent shorting. Those are used for power antennas & amplifier trigger.
Aug 28, 2011 | Car Audio & Video
1990 ford telstar tx5 AT 2.2lt fuel injected motor
Is the spark plugs getting spark? Is it getting fuel?
Apr 17, 2010 | 1990 Ford F150
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
Oct 23, 2009 | JVC AM FM CD DET FACE CAR STEREO
Radio wiring
The JVC unit has a RED wire, it sounds like this is connected to a power source that is ON with ignition...this is OK. Your unit also has a YELLOW wire, and it sounds like this also connected to a power source that is ON with ignition.....NOT OK....this wire needs to be connected to a power source that is On all the time.
Mar 12, 2009 | Car Audio & Video
JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Dec 14, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
