I am trying to print a couple of documents. One is 3 pages, listed names numbered from 1-40 it only prints from #19-25 (top of second page). The other is a direct depost check stub and only prints header/
  • 4,737 Answers
It would be better for me to help you if you had mentioned the program you are using, any follow these instructions. After you open the print command, (on the Print Dialog box) Select "Document" at the "Print What" Menu, and click Ok, You can refer to the picture shown below: I am trying to print - c982c70.jpg
Sometimes this problem is related to the cartridge, but let's do it after you verify this, do let me know if it doesn't solve, let's try another method. Good luck.
Posted on May 29, 2010
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
How do increas the print size in my computer?
open a document you want to print select file in the top left hand corner then select print preview from the drop down list ther should be another drop down list with percentages
30%
40%
50%
etc....... this is on a web page
the same should be on the page if you have made a word document
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the
sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
hope this help you
Aug 19, 2011 | Computers & Internet
I am unable to print documents from my HP 2600n laserjet printer. The only item that I have been able to print today is a couple of TEST copies. Otherwise, I have not been able to print any documents. I...
Thanks for posting to Fixya and it is my pleasure to guide you.
Since you have been able to print test copies, that tells you that your printer is working.
Questions:
1. Did you print the test from the front of the printer, from the control panel or from a document?
a. If you printed from the printer then
b. test print from the control panel Printers & Faxes then
c. from a document.
1.a. From control panel, double click on Printers & Faxes. Click on the printer that has a check mark, indicates your primary printer, and right click and properties. Click the Print Test page at the bottom. If you get a test page then goto
1.b. Open Word and type the phrase "Test Print" in the document. Click File and Print. Look at the top of the dialog under Printer. You should see your printer name. If not, click to arrow at the right and pick you printer name from the list. Then click OK to send the document to the printer. If you get the page to print then you are done. You should be able to print from any source.
4. If that did not solve the problem then be sure to write down any errors or numbers and post back.
Good luck and please post back that you are successful and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | HP Color LaserJet 2600n Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
Need to access fax in memory
lindalacasse --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 08, 2009 | Canon PIXMA MX310 All-In-One Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
Nov 28, 2008 | HP Office Equipment & Supplies
12 people viewed this question
k24674
