Question about Kenwood KAC-7202 Car Audio Amplifier
Every time i turn my amp on it blows the fuse what do u think is wrong with it?
  • 1,868 Answers
Hello! Is this a new installation? If so re-check your wiring... If not, tell me what the year, make, and model of the vehicle...Also identify which fuse is blowing; vehicle fuse or in-line amp fuse?
Guru...........Saailer
Posted on May 29, 2010
I am looking for the proper fuse needed for this amp. I keep purchasing the wrong ones
The fuse rating should be printed on the panet right by the fuse holder. If there's still a question about values, you're best bet is to contact Crate customer service.
Here's the link-
http://www.crateamps.com/support
However, if you're meaning that you keep blowing fuses and therefor think you're instaslling the wrong value, you may have a short in the amp that's casuseing the fuses to blow. In that case, it needs to go to the shop. If you're not a tech, don't poke around inside it. You can make the problem worse, or even get a nasty shock.
Mar 31, 2016 | Crate FlexWave FW120 Guitar Amp Combo w...
97 chey blazer alernator overcharging, blowing fuses
Sounds like the 10 amp fuse was too small to begin with. Possibly the old alternator was too weak to blow it. 20 amp sounds more like it. Someone probably stuck the wrong fuse in at some time.
Jul 12, 2014 | Chevy S-10 Blazer 90-97 BT-1858
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
I have "cooked" (i think)
When the fuses blow like that suspect an overload in either the power supply or main amp stages. I think you might have damaged one or more of the output devices. They can develop faults quick if you're using the wrong type speakers or have faulty wiring to them. The main cause of fuse blowing is a semi-conductor device that is acting like it is a piece of wire. For instance an output transistor when connected to a multi-meter on the ohm scale, will show a full scale deflection, just like if you had touch the two test probes together.
Nov 20, 2010 | AudioSource AMP-100 2-Channel Amplifier
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
10 amp fuse blows when you turn on tail lights
Check your tail lites to see if you have rust or a grounding on the hot side of the wire seating or the wrong bulb or wrong fuse.
Jul 26, 2009 | 1988 Chevrolet Corvette
30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Apr 12, 2009 | 1996 Hyundai Accent
Amps
If the amp blows a fuse with no remote voltage applied, the amp has a short in the primary side of the power supply. If the fuse only blows after remote voltage is applied, the amp probably has shorted output transistors.
May 02, 2008 | Boss Riot 1500D Car Audio Amplifier
Blew the fuse
YOU CHECK THE CAR FUSE...BUT THE STEREO HAVE ANOTHER FUSE. CHECK IT IF PROBLEM PERSIST.... I´M SORRY BUT I THINK YOU BLOWIT ,YOU MUST GO TO REPAIRED SOME TIMES BLOW A THIN LINES INSIDE THE STEREO AND REPAIRED THOSE WORK AGAIN AND POWER AMP IN THE STEREO BLOW TOO. GOOD LOCK!!!!
Feb 16, 2007 | Alpine CDA-9855 CD Player
Kenwood KAC-7202 Car Audio Amplifier Logo
117 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
