I have an Auria LCD TV. The power come on but
I have an Auria LCD TV. The power come on but there is no image ... also the remote control and the tv buttons don't work ... so I have to unplug the tv to turn it off.
  • 16 Answers
SOURCE: NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Posted on Oct 09, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
I need a remote control that will have for auria
0071 0101 0113 0152 0181 0236. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 24, 2014 | Televison & Video
Auria tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Need the codes for a auria remote to run a samsung tv?
go to www.remotecodlist.com or memorex.com or www.fitness.manualsonline.com
God bless you
Jul 25, 2012 | Televison & Video
Auria eq2288f 22" lcd tv
What has happened is that one or more of the back light tubes were broken in shipping, AURIA used hard foam packing and the TV could not handle the shock of shipping because of BAD PACKING from AURIA. if you call customer support they will tell you that is a power supply or inverter issue but it's not it's a broken bulb, you know they know about it because they will not tell you one or the other. if you open the Samsung screen (LTA400HM01) you will see that the bottom back light bulb is broken, why AURIA will not address this issue is beyond me. don't waste you time or money on power supply or inverter boards before you look at the back light bulbs.
Jan 19, 2011 | Televison & Video
I can not progam my disk network remote to control my new Auria tv. i can use most functions except to on/off and volume
Hi, this is Cheri Torres with DISH Network customer service.I came across your question and wanted to see if i could help. :) I was lookingthrough all of our remote codes for all of our IR remotes and I didn't see anycodes for Auria TVs. An option you can try instead of using remote codes is a channelscan. A channel scan will basically go through all of the possible codes wehave and find the correct one for your particular remote and TV. Whendoing a channel scan you will first have to press and hold down the TV buttonon your DISH remote until all the mode lights at the top of the remote light upred. As soon as all the lights are lit, let go of the TV button, press 500, andthen the # (pound) button that is located under the number nine. After thisprocess is done you will press and hold down the TV button again until all themode lights are lit. Then you will press the big red power button once andrelease, next press the up arrow button once every second. You will keeppressing the up arrow until you see your TV turn off, as soon as the TV turnsoff you will press the # (pound) button right away. Once you have completed allthese steps you can try all your TV functions to make sure it is workingcorrectly. I hope you find these instructions useful. If you have anyfurther questions or concerns feel free to post back here or email me atCheri.Torres@Dishnetwork.com.
Dec 29, 2010 | DISH Network IR Remote Control
Auria tv model eq2288f. The power would come on but there is no image. You can turn on with remote but would have to unplug to cut the power off...
I have this same problem. The power supply board is bad, though all of the capacitors appear to be fine. No brown spots, no burnt connections, no puffy caps.
The power supply part is R0800-0810D and I can only find it on ebay for $50 plus shipping.
May 13, 2010 | Televison & Video
AURIA TV MODEL eq2288f. The power would come on but there is no image. You can turn on with remote but would have to unplug to cut the power off...no reset button
I don't have the solution I have the same problem. Does anyone know how to correct this issue. I tried calling the given repair ine and it is no longer a wiorking number. I have only had this tv for 8 months.
Apr 01, 2010 | Televison & Video
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
