Question about Canon PIXMA iP90 Mobile Printer
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
    Sergeant:
  • 284 Answers
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
Posted on May 29, 2010
MY CANON IT NOT WORKING IT'S FLASHING 8 TIMES
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon PIXMA iP90 Mobile Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
  • Before resetting printer canon iP90, start with printer power off .
  • Green LED indocator will blinking and then stopped blinking.
  • Press power button and the printer power will off. otherwise off, depress again power button.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon ip 3300 flash 5 times orange
pixma ip3300 flash orange 5 times, i remove all catridge / remove print head and orange flash 5 times. help!!!
Sep 18, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon mp730
Hello there Hi there you can try.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 02, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Aug 07, 2008 | Canon PIXMA iP90 InkJet Printer
Canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Mar 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
566 people viewed this question
old marine
old marine
