Question about Maytag MSD2351HE Side by Side Refrigerator
MAYTAG MSD2352HEW. Freezer working fine. Cooler does not work. What's the problem.
  • Maytag Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorMAYTAG MSD2352HEW. Freezer working fine. Cooler - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 29, 2010
Why the freezer works fine but cooler doesn't
Air flows from the freezer to the cooler. Either the fan in the freezer is not working or the vent is frozen over. This typically is a defrost system problem.
May 03, 2014 | Siemens Refrigerators
Kenmore Trio Elite Refrigerator (Model 596.76583601) Won't Cool, Freezer is Fine
the coil needs to be defrosted or the defrost timer is bad also go to sears.com and you can download a manual :) hope i helped a bit
Sep 01, 2012 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Fridge and freezer warm. Mildly cooler air is coming out but the settings are on 7 for both fridge and freezer which are the coldest. Hard to tell if its actually cooler air or just seems that way because...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Maytag MFD2560HES Bottom Freezer French...
Fridge not cooling, freezer is fine
Did you adjust the fresh food setting to cooler. If so, I would suggest you take the back off the fridge and vacuum and clean all the coils and compressor. If that doesn't work you probably need a new one.
Jan 02, 2011 | Maytag Refrigerators
Freezer is working but lower cooler is not. did hear a clanging noise befor the lower unit gave dup?
Check for a bad heater ... remove plastic floor inside of freezer and ohm the heater ... Please rate this ..
Aug 05, 2010 | Maytag MTF2156GES Top Freezer Refrigerator
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Hi
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Admiral refridgerator freezer works fine but cooler section not cooling. had ice in back of cooler section.
it may be a timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 also ...do not damage coils with freon in them
Aug 25, 2009 | Maytag Admiral Top-Freezer Refrigerator
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD2351HE Side by Side Refrigerator Logo
90 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
