Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
How to get dish drawer from under bench
I have lost my manual for my dish drawer and want to remove it from under the bench to attend to the access that mice are getting through which I am sure is behind the machine.
Please can you help as am unble to get at the two small bracket at the side toward the rear of the machine.
I understand I need to remove the drawers, but have no idea how to do this.
Please can you help. My dish drawer is about 8years old
Thanks
Mary
  • Fisher and P... Master
  • 3,247 Answers
Go to page 7 on this installation manual
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
to find out how to remove the drawer. The location of the brackets is also shown.
Please rate this solution if you are satisfied otherwise post a comment.
Posted on May 31, 2010
Why is the swing arm that is under the upper drawer not getting any water?
The pump may have failed, or the pump intake (under the lower drawer) may be clogged with crud from years of washing dishes. It can be removed for cleaning, although it's not a super-simple job.
Aug 01, 2014 | Kenmore Dishwashers
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
My dad lost the manual to his 606 Model # 640DORS. We can't figure out where you change the temp.; the person who installed it several years ago, turned the temp. way down, and in the winter, it doesn't...
Remove access door usually on upper side of unit. Will need to unscrew retaining screws. Under cover is a thermostat that you can adjust to your liking. Reattach cover when done.
Sep 06, 2010 | Reliance & 40 Gal Electric Mobile Home...
My kids put liquid dish soap (not for dish washers) into the hole where you put special rinse product. We got all the soap out of the hole and took towels to dry out the tub, but F1 comes on even when the...
You can download the user manual but that may not help you solve the problem.
I can see that there has been foaming in the dishwasher due to the incorrect detergent which caused the flood switch to trip.
You will have to take both drawers out and dry out the flood switch at the base of the housing from inside. You will use towels and hair dryer.
Make sure the power is turned off at the circuit breaker.
See the installation manual on page 7 step 2 to find out how to remove the drawer. Make sure you don't pull out carefully so the hoses at the back don't get stretched.
Aug 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The upper and lower dish drawers leaves a puddle of water under each (maybe 6" in diameter) after the shortest cycle. There is a small amout of water left in the clear protective housing on the underside...
The drawers slide on a pair of rails on each side of the housing.
see installation manual page 7 to find out what you need to do to get the drawers out. The instructions are for an older model but it should be similar setup for your model.
May 18, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
I've lost the manual. Where does the rinse aid go in the dish drawer?
the rinse agent will go below the soap dispensor, remove the screw top where a light should be shining through
Oct 31, 2008 | Fisher and Paykel Dishwashers
Fisher and Paykel double drawer dishwasher
Hi. I am a plumber who has had this problem before. To reset the flood switches you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Oncw the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position. This procedure literally takes me about 3 minutes and should save you about $120 for a serviceman to come out. The principal is the same on all dishwashers its just a matter of locating the reset switch. All the best and save yourselves a fortune.
Jan 09, 2008 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
156 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
