Question about Microsoft Wireless Desktop Elite Keyboard/Mouse 2090265223
I have an hp touchsmart desktop computer. However, my usb transmitter to operate a wireless keyboard and mouse is damaged. How do I replace and get a new usb transmitter
    Master:
  • 645 Answers
If it is within warranty, u can call up the tech support and they will replace it.
If it i snot within the warranty period, u will have to get the whole unit including the USB receiver, wireless keybosrd and the wireless mouse.
Posted on May 29, 2010
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
I cannot get the mouse to see the computer. I've changed battery, re-set button on both mouse and USB transmitter. It is properly installed on the desktop, and the red light is on on the mouse, but it does...
the mouse or the receiver is not detecting, also if its windows xp and earlier get the drivers and it will be ok, or simply the mouse itself is faulty.
Oct 02, 2013 | HP Wireless Optical Mouse
Do i need a keyboard and a receiver for the mouse to work and if not how do i hook it up
Your wireless mouse and Keyboard work with the same wireless transmitter that is plug in into a USB port.of your computer. You can use the wireless mouse with that USB transmitter and dont use the wireless Keyboard. If you need a keyboard you can get one to be plug in into a USB port with the wire attach to the keyboard.
Mar 23, 2012 | Micro Innovations KB982W-F Wireless...
Not conecting to computer
When you install a wireless mouse, first make sure your USB transmitter is plugged into a functioning USB port.
Then make sure the mouse batteries are fresh and installed correctly.
Once you are set, turn the mouse over and push the "connect" button on the bottom. Note: if your transmitter/receiver has a "connect" button, push that first.
Feb 22, 2011 | HP Wireless Optical Mouse
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
I lost the transmitter for my wireless keyboard/mouse
Buy a new one. & dont forget to check this time ;)
Jun 02, 2009 | Computers & Internet
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
HP Mouse does not Work
if you have a reset button on usb press
also press reset on transmitter
also check your mouse settings in control panel
if this all fails then use a different port for mouse and restart system
let me know if solved and don't forget to rate
Feb 08, 2009 | HP Wireless Optical Mouse
Wrirless keyboard
The mouse or keyboard does not work at all
If your wireless mouse or keyboard is not working properly, check the following:
  1. The mouse is designed to enter a suspend mode after 20 minutes of inactivity. Try to reactivate the mouse by clicking the left mouse button.
  2. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
  3. Restarting the computer may resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
  4. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface.
  5. Verify that the batteries are correctly installed in the keyboard and mouse. If possible, use a fresh set of alkaline batteries.
  6. If the receiver is a USB receiver, unplug it, wait for five seconds, and then plug it back in. Wait about five more seconds and then test the mouse and keyboard again.
  7. Reset the keyboard and mouse connections :
Note: The following connection sequence must be completed within 60 seconds.
With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
Note: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small Connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a Connect button - skip this step.
Jan 12, 2009 | Computers & Internet
Microsoft Wireless Desktop Elite Keyboard/Mouse 2090265223 Logo
238 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
