I have a kelvinator excellence 6.5 smartdrive9 top loader.The 3rd led,shortwash led,spin led and the one before the spin led is on and beeping. The machine will not fill and pulses in short bursts then stops and beeps. the washer emptied after a wash cycle and would not spin.tried cold water only and this did not do anything as it just pulsed and then went into the same error code. I have previously replaced the hot water solenoid, could this have happened again?....Your response would be appreciated.
  • Washing Mach... Master
  • 713 Answers
Your machine is a fisher and paykel, just re-badged. now the fault you have is your " OUT OF BALANCE" switch is faulty, probably due to corrosion . the switch is located under the control module which is under your display panel. if you choose i can guide you thru the repair. please reply 4 further help
Posted on May 29, 2010
  • 2 more comments
  • faila Sep 27, 2010
    can you please guide me thru the repair i have the exact same problem
  • luisa_sgro Sep 27, 2010
    Hi just read your posting.Now remove the 2 screws at the top of the top panel.Pull the top panel gently away from the machine as there is the display wiring still attached.Rest the panel on the lid and the please reply with the color of the control module.This will help me accurately guide you in the replacement of the switch.Looking forward to your reply.
  • originalgeor Aug 14, 2011
    still able to reply? I need help too! I have the same problem
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
MW511 top loader washing machine. 3rd & 4th LED lights are lit and beeping sound is heard. When Start/Pause id pressed, the above lights go out and Lid Locked lamp comes on. When Power button is...
The third and fourth lights from the left indicate a failed motor controller (error code 48) If this is the correct fault code you will have to replace the motor controller. However before that is done all the electrical components which can effect the controller must be checked as well...Best to call a tech...Good luck Nomess
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P Smartdrive9, excellence 6.5Lt motor restriction
Tipped the washing machine over to tip out the washing and water, gave the thing a shake, hit some parts with a soft faced hammer adn she worked!
I think that process dislodged a blockage in the water pump...
Jul 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
406 people viewed this question
Top Washing Machines Experts
