Question about Amana ALW880WH Top Load Washer
Water Drains out as fast as it is filling
My Amana washer is filling with water, then the water is just draining out.
  • 135 Answers
You have too much of the drain hose inside the drain line causing the water to siphen out as its coming in. Pull some of the drain hose out and secure the hose. There should only be about 8 inches or so of the hose inside the pipe.
Posted on Apr 08, 2008
4 Suggested Answers
SOURCE:
  • 294 Answers
SOURCE: water drains out as fast as trying to fill
hello, have you checked to see if your drain valve is'nt stuck open ?
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: water leak
I WISH I COULD HELP YA. LET ME TAKE A SHOT AT THIS: IT SOUNDS LIKE A HOSE IS LEAKING ON YOUR WASHER. HOW OLD IS YOUR WASHER?
RODNEY
Posted on May 14, 2009
  • 6 Answers
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
Filled with water. Took towels out - would not spin. Unplugged it. Now it tries to drain but stops and lid unlocks.
Amana , Whirlpool Washer Repair - Not spinning or draining ...
? 1:50
www.youtube.com/watch?v=q7ey58YZrm8
Jul 2, 2013 - Uploaded by ApplianceVideo.com Repair your own Amana Washer with these following issues: Not ... How to Fix a Washing Machine That Does Not Spin (Fast and Easy) ...
Sep 17, 2015 | Amana Washing Machines
My bravos top loader will not fill up with water. The water drains as fast as it is trying to fill up. As a result, the wash cycle never completes.
You must make sure the drain hose is above teh water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
Kelly
Mar 27, 2011 | Maytag Bravos MTW6600T Top Load Washer
Water drains out during the wash or rinse cycle
check your drain hose if it is down the drain to far it will **** the water out even while it is filling it sould only be in about 2-3 inches
Jan 23, 2011 | Amana NTW5400TQ Top Load Washer
Water continues to try to fill the machine but just drains out drain remains open
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 01, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
Water drains out as fast as trying to fill
Mar 31, 2009 | Washing Machines
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Amana ALW880WH Top Load Washer Logo
115 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
