I have a dr error code in a Frigidaire front load washer machine model GLTF2940FS1
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error ‘Dr’ means door error which means that the sensor (PTC sensor) inside the door latch is not sensing that the door is locked. TO resolve this issue you’ll have to replace the door latch assembly. To replace this latch assembly you’ll have to start with removing the outer ring which holds the rubber gasket. After this is done then you have to take out the screws holding the latch assembly and pull out through the front. Please make sure all this is done while the unit is unplugged. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 29, 2010
How do I find the control panel that controls the pump motor? Due to error code E23?
Frigidaire GLTF2940FS1 washer Error Code E23 ...
www.shopyourway.com > Manage My Life > Questions
Sep 13, 2013 - My washer stopped mid-cycle and emitted a burnt odor. Troubleshooting shows error code 23. I pulled the connector off the pump and have ...
Kenmore Washer (48112) E23 error code ' ShopYourWay
Get shopping advice from experts, friends and the community! Hey all, I have a Kenmore front load washer model #48112. When I hit the start button the NO ...
Oct 23, 2015 | Washing Machines
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
I have a dr code in the display of a Frigidaire front load washing machine model GLTF2940FS1
DR means the Door is open. You may have a faulty door switch, very common. However you must perform the troubleshooting procedures.
http://frigidaireservicetips.com/pdfs/490_3cuftHorizontalAxisWasherSM.pdf
Please use your service manual above to troubleshoot and repair your washer.
http://www.washerhelp.co.uk/diy-repair-help.html
Above is a DIY washer repair website, between the two, the service manual and the website, you should be able to troubleshoot and isolate your issue.
http://www.partselect.com/Blog/archive/2008/09/16/frigidaire-appliance-fault-codes.aspx
Error codes explained. Below is a compendium of the same. http://appliancejunk.com/forums/index.php?topic=2846.0
May 29, 2010 | Washing Machines
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer door problem
Most likely the door lock is bad, check the wire connections to make sure thay are connected. If so replace the door lock assembly.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
