Question about Garden
I have a poulan woodshark p 3314wsa it starts and runs, but chain doesn't turn
    Problem Solver:
  • 4 Answers
Does the chainsaw seem to rev up without any resistance, or does it bog down as you push the throttle? If it revs up quickly, then it sounds like the clutch plates may be frozen - usually due to rust. If it boggs down, then the chain and/or clutch housing are frozen or stuck somewhere.
The chain drive uses a centrifugal dry friction clutch with two weighted plates that are spring loaded. The springs keep the plates disengaged from the clutch housing to allow the engine to spin freely at an idle (or slip when the chain slows down due to the blade binding).
When you press the throttle, the engine revs up and the higher RPMs create centrifugal force causing the clutch plates to push outward - fighting against the springs, and begin creating friction on the inside of the clutch housing. If rust prevents the clutch plates from moving out to cause the necessary friction, the clutch housing (and drive gear which is permanently affixed to the housing) won't spin and the chain won't move.
With the engine OFF and cool...first take a thick towel or rag and place it over the chain with the engine switch in the OFF position. Try to move the chain in the normal rotation (top forward, bottom backward) to see if the chain moves freely or if it is stuck in position. If it does move, then take off the chain cover and then get a can of PB Blaster and spray the clutch plates and springs. Give it an hour or so and then take a rag and wipe off the excess and reassemble and try it. The excess PB Blaster will burn off with the heat of the clutch and the rust will no longer be a problem.
If the chain won't move, then somewhere along the drive the chain or clutch housing are stuck. Look for a bend or kink in the bar where the chain rides.
Posted on Jun 01, 2010
When engine is running the clutch will not turn. What could the problem be?
Sounds silly but have to activated the chainbrake by accident.? The black handguard by the top handle is the chainbrake.! Pull it back to de-activate the safety chain brake. It works by activating a brake band around the clutch drum, stopping the drive but the engine still runs, however if you try and rev it the engine will struggle under load because the clutch is trying to drive a drum which is being held by the brake.
Jan 07, 2016 | Poulan 14 Woodshark Chainsaw
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
I JUST BOUGHT A NEW POULAN WOODSHARK CHAINSAW AND IT WILL NOT START
hello red.... how aggravating. Check to be sure the chain is not too tight. Check to be sure it has the right mix of fuel and oil, a clean filter, and a new spark plug. Then get a can of starter fluid and a helper. Remove the air filter and have your helper squirt a little starter fluid into the air intake. Once it starts have the helper continue to squirt starter fluid until it will run on it's own, usually a couple of minutes. Joe
Apr 15, 2011 | Garden
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
I have a poulan 14 inch woodshark chainsaw and it ran fine when i got it but now i have to keep gunning the gas to keep it running and i have cleaned the air filter and cleaned the carb.
Turn up your low speed jet about 1/4 turn. You have 2 holes in the side, one says slow or low and the other says high,, or fast, turn the slow jet in 1/4 or out if that doesn't work, then try it, you will find the right spot. Hope this helps.
Mar 13, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
What is the breakin period for a poulan 1950
I would say a full tank of fuel, but there really is not any " break in" time stated in maual.
Feb 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Woodshark poulan 14" slack chain
make sure the little tooth on the end of the adjuster for the chain is locked into the groove its supposed to go into and tighten it down.
Note: the chain is supposed to get loose on you but not as quickly as it is. maybe after an hour or so of cutting.
and as for it not cutting well, the chain may need sharpened.
if it has been sharpened once by someone than take it to someone esle if it is not satisfactory.
Jan 11, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan woodshark 1950 gas to oil ratio
Thats and old saw, you have to run those very rich usually 20:1
Aug 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
Garden Logo
362 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
