Question about JVC RM-RL1 Remote Control
Cant find the OK button on my JVC big screen tv remote! i need it to auto program my TV
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Http://www.xdiv.com/remotes/
Posted on May 30, 2010
Need Remote codes and directionsto program Emerson TV to a Big Matters Jumbo Universal Remote
Hello
Setup codes for Emerson TV with Big Button remote control are:
001 029 033 045
048 049 052 091 139 141
157 162 214
OK.
Oct 16, 2011 | Big Button TV Universal Remote
What is the code for my hd 52786 jvc tv trying to program a dish network remote
Try these codes, the bold ones work the most often: 557, 558, 642, 559, 508, 649, 655, 667, 673, 676, 726, 735, 736, 737
If the codes don't work try the steps below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Feb 02, 2011 | JVC RM-C14G-1H Remote Control
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I need codes for TV JVC
The codes for JVC TV to program universal remote are
159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158.
You can check these codes one by one and for programming, get instructions from the given link:
Programming
  • Press device and OK buttons at the same time [2.5 sec.] DEVICE LED turns on
    Input three digit code number....DEVICE LED blinks with each number entered
    Press DEVICE LED again it blinks twice and then turns off
  • You can manually search for a code by having the TV turned on and use the up or down button on the remote..
    When TV turns OFF,,,,, that's the code
Jun 29, 2009 | Philips Universal PH301S Remote Control
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
How I can program ViewSat remote to control JVC TV Volume
You need to hold down TV until all the lights on top cycle through. Then TV button should stay lit up. Press the channel up button do this with the TV on until the TV shuts off then press ok.And you should be good to go.
Jan 28, 2009 | JVC RXD301B
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
JVC RM-RL1 Remote Control Logo
266 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
