Question about Lenovo 3000 J Series 1.80G VBE PC Desktop
Lenovo j3000 no video is it the mother board - Lenovo 3000 J Series 1.80G VBE PC Desktop
  • Lenovo Master
  • 5,660 Answers
1) Check the monitor cable first.
Use it on another computer, if available. Also try the other monitor, and monitor cable, on your computer. Rule out whether it may be the monitor, or monitor cable.
2) It's a Lenovo 3000 desktop computer, and one of the J series, apparently.
Which one of the J series is it? Just two examples, J110, and J115.
The Lenovo 3000 series desktop computers come with Integrated Graphics.
This means the GPU is soldered to the motherboard.
[GPU = Graphics Processing Unit.
If the GPU is soldered to the motherboard, it is Integrated Graphics, or also known as OnBoard graphics.
ON the motherBOARD.
A GPU can also be soldered to an adapter card.
Graphics adapter card, or usually just referred to as Graphics Card.
http://en.wikipedia.org/wiki/GPU ]
Let's say the Onboard (Integrated) graphics GPU, is bad on the motherboard.
The Lenovo 3000 series desktop computers, have a PCI Express x16 slot on the motherboard, which is used for a graphics card.
GPU is bad on motherboard? Install a graphics card.
Plug the monitor into the graphics card.
(Don't forget to install the drivers off of the CD that comes with the graphics card, First.
Then install the graphics card)
3) Let's also go back for a moment.
No video on the monitor, (Or also can be said as no graphics on the monitor. No Signal), can also be attributed to the fact, that the computer is Not working.
It may seem as though the computer IS working, however.
Lights may come on. Fans may spin, and it may sound as though the Harddrive is operating.
Problem is the Processor isn't operating.
The power of a Power supply is generally rated in Maximum Wattage.
(Voltage times Amperage = Wattage)
[There is one more power factor to consider, when stating the maximum power rating of a power supply.
The Amperage of the volatge power rails, but we don't need to concern ourselves with this at the moment.]
1) ALL the lights use Less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use up to, 51 to 125 Watts.
Depends on what Processor it is.
Using the Lenovo 3000 J115 7387 desktop computer for an example, the standard Processor that comes with it is an AMD Athlon 64 X2 4200+ processor.
(AMD Athlon 64 X2 4200+)
The AMD Athlon 64 X2 4200+ processor, can use up to 89 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Manchester.22_.28E4.2C_90_nm.29_2
(TDP)
No Processor running, No computer.
No computer, No graphics on the monitor (Video)
[The Processor is the 'Brain' of the computer.
No Brain, there is nothing to find the boot sector on the Harddrive.
The Harddrive spindle motor just spins the Platters inside the Harddrive]
To summerize:
The Power Supply may have a weak Voltage power rail, and not have enough power to turn the Processor on.
Just enough power to run the hardware components, that do not use very much.
You can test the Power Supply, or replace it with a KNOWN to be good Power Supply that is compatible, for a test.
Should you wish to test the Power Supply you will need a multimeter, or a power supply tester.
Posted on May 31, 2010
I want to replace the CMOS Battery in IBM 29R9284 mother board. But I am not able to locate the CMOS Battery in the mother board. Can someone guide me on this to know whether any CMOS Battery is installed...
Hi, here you can download drivers and a manual:
http://support.lenovo.com/en_US/?sitestyle=lenovo&lndocid=MIGR-56602
You can use the autodetect function in seach for your model.
IBM has changed name to lenovo.
The cmos battery look like this:
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=r4fDSQap2Qo&playnext=1&list=PLD78BD157A0D15923
Hope this will help you.
Aug 21, 2011 | IBM 29R9284 Motherboard
My lenovo s10-2 no displayed on the screen when i turn it on. i see the fan working
1. Possible bad video card ( on the mother board)
2. Loose video cable (internal)
3. Possible bad hard drive possibly needs replacement.
Jul 15, 2011 | Lenovo Computers & Internet
I have a Lenovo 3000 n100 laptop and I want to change the video card to Nvidia GeForce 3 or higher due to my wanting to play certain games on my computer but unable to do so. How do I go about doing this?
unfortunately that model either comes with an Intel video card or the Geforce go 7300 Turbo cache, neither which is interchangeable, your only option if you have the motherboard with the Intel Chip set Video card is to find a mother board with the Geforce chip set and swap out mother boards,
Feb 23, 2011 | Lenovo 3000 N100 Notebook
CAN YOU HELP ME TO LENOVO 8S661FXMTIU DRIVER FOR MY MAIN BOARD
i want to download sis mother board no 8s661fxmtiu vga video graphic
Mar 16, 2010 | Intel Motherboard
Failure to boot Lenovo J3000.
check 1st a ATX power supply if this a good 2nd remove the memory then make a clean using a paper eraser clean all the pin connectors of memory....
May 23, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
SOUND DRIVER AND VGA DRIVER NO INSTALL
You can download the drivers for your PC from this link: Click here Here you will find a drop-down menu from which you can select Audio for sound drivers and Video for VGA drivers. Hope this helps...
May 04, 2009 | Lenovo ThinkCentre A55 PC Desktop
Hi, i lost my cd drives of lenovo 3000 j series system how to download the mother board drives plz help me
just go to the lenovo website. give the lenovo serial number and serach it. you will find the software for system board. download it.
Jan 20, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Lenovo 3000 J Series 1.80G VBE PC Desktop Logo
1,231 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
